  • Replies 47
Posted Images
Is this the same GTR that had a lucky escape at Calder Park, on a WRX track day, in Feb?
If not, i also remember seeing another very neat silver 34GTR at Sandown.
Good luck with the repairs, all the best.
PS: AU's suck!! Mine has gone through 2 auto transmissions, one gas converter, 3 dash inserts, numerous gasket seal, etc. The only thing worse than the AU, are the mechanics at the Ford dealerships :D. But as i stated b4; It's all good when it is free :yes:
No, the only WRX track meeting i've been to was Sandown in June.
Cheers,
Neil
curious question to those who've seen the wobbles with trailers.
what tyre pressure were u running on the trailer tyres?
I had the wobbles so many times, but never checked the tyre pressure.
Problem with my tow car is its to damn low, which puts too much weight to the front....plus some of these hire trailer really sucks.
That nearly happen to me coming back from Winton....I had to keep in under 100 to keep the trailer steady.....And my tow car is a FORD.
I thought this was normal. 60mph or 100kph is the legal limit in the UK for trucks and cars towing trailers. As trucks are 100kph here I assumed trailers were the same.
Sorry to see the mess and glad it can be fixed.
BTW I would like to nominate the taxi in my siggy for the sexiest 4 door Ford ever made :D
That sucks Niel. But I'm glad to hear you are ok though.
The first thing I did on the drive up to Sydney when I got the wobbles was stop and check the tyre pressures and they were all fine. The wobbles tend to come on during a down-hill section where the trailer trailer tries to go faster than the car. This is made worse when the tow car is lighter than what is being towed (which is consequently why it's against the law to do it in Vic).
Sorry to hear of the accident and injury Neil. Hope all is well soon
I have several hundred thousand kays towing weird loads doing heavy recovery and repair for Army. When you put a car (or any sprung load) on a trailer you are more prone to the trailer getting the wobbles and tank slapping. One of the biggest problems is the silly over tyre retainers that people use. They are so common now but really are just scary.
One of the problems we had where I got to test and quantify the failures and solutions was where I ran the Army trials on the ASLAV 8WD fighting vehicle transport solution and aside from putting wooden blocks underneath and chaining down onto them the next best was to pull the vehicle down hard on the suspension. Unfortunately someone a whole lot smarter (ie. has more rank) decided to change to tyre straps and driver constantly complain about the instability so it's a matter of time before another serious fallover. The same is true for cars, buses, trucks, I've even had a triple trailer road train hooked up behind the 286hp Mack Wrecker (massive 11 litre 6 cyl engine with huge turbo so small peak power but wicked torque into a 5 speed crash box). All vehicles move around on their suspension causing the trailer to move in an unpredictable way. A tyre down on pressure can be a cow as well.
What Snowy said about the brake is a good temporary cure. Set the brake a little tighter on the actuator and it keeps the trailer pulled in behind, especially down hills where it wants to overtake but wears the brakes out. If it's a rental who cares but you do want brakes for when you have to stop.
Braking slightly is usually the best method but is a bit hard with rentals as they rely on the pressure in the piston to start to slow. If you have a trailer remote brake overide then use that to pull the trailer in behind until you can pull over and fix properly. Ultimately properly restrained to the trailer is the only real solution.
As for Fords being crap, I've owned several and still have one in the driveway I use for towing the 6x4 and have no problems with them. Also I don't recall a GTS4 owner ever beating me in any event on the track or DECA, so does that mean they are crap drivers and have to hide behind AWD to cover their faults???? :D
BTW Snowy you might find it's only against the law where there are no trailer brakes fitted which all car trailers I've used have, usually a brake overide system but they need a little adjustment to get right. How else do people tow their really large boats/operate primes with a tri-axle trailer.
What stuns me is there is no special license to use a trailer. You have car license so you are automatically good to tow??? And the govt says they are getting tough on road safety. BS!! We have people who can't parallel park that can legally tow (and one would assume reverse and restrain a load correctly IAW state and federal requirements) with no extra training.
Cheers Andrew,
The tyre pressures and trailer hook-up (ride height) were checked by the trailer hire guy. I guesstimated there was between 100-150kg of weight on the tow ball (it's recommended that you have 5-15% of the weight being towed on the tow ball), I stopped twice between Ararat and Ballarat to check that nothing had moved, and the car was tied down with webbing and rope plus the steel winch cable. I was cruising along at 90-95km/h and everything was handling fine until the long steep downhill section at Pikes Creek on the Western Hwy when the fishtailing started, and didn't stop despite attempted acceleration (the suggested method of correcting this problem).
Apparently, it is legal to tow up to 1.5 times the mass of the towing vehicle with a braked trailer - not that I'll ever try this again - the car will be delivered straight from the repairers to Racepace by truck!
Most importantly, AAMI (Ford) and Just Car Insurance (GTR) have covered the damage. Though I'm sure the insurance on the GTR will skyrocket next time the policy is up for renewal.
When I say "relatively'', if it was a commodore and not a GTR, it would have been about $12,000 to fix, but because of the price of parts etc on the gtr you can multiply by about a factor of 4!
All panels down the passenger side rooted, nose ripped off (going to put a nismo front bar on as a replacement), passenger side suspension components damaged etc.
man i cant say i feel wat ur going through but i got some idea....i currently own a r34 gtt and is no where near as crazi as sexy gtr but its been smashed off the road into a pole by some commodore driver. id proberly be crying if it was a GTR....i hope everything goes well man...hopefulli ill see u around some day...where bouts are u usually
Edited by anjoO
Sorry to hear Neil, good thing you came out unscathed...
Its quite dangerous towing a big car like a GTR on hired trailers, most of them are rated at 1200kg towing capacity, and having a 1600kg GTR on it is quite risky. That aside it makes life easier if you have quite a large tow vehicle such as a 4wd to stop the trailer pushing the car down hills..
You'd be surprised how many incidents like this I come across.....
Sorry to see something like this mate, hope all works out well.
As for those with the silly comments, there is no need for that, could happen to anyone. I'm sure this is hard enough on the owner without wise cracks...
Dane
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
