Hi,
I started this thread back then when I had a N1 R32 GT-R and there was little information on rare Skylines.
This thread has largely been replaced by:
http://www.gtr-registry.com
That site has everything you'd ever want to know about Skylines.
This sounds interesting. Got pictures?
Heres a few original pics of the car on stock R34 rims.
Build Date: 11/1997
ECR33-133971
1997 Series 2.5 R33 GTST Turbo Coupe Automatic
LP2 Midnight Purple
Originally registered here with 96,400kms, currently has 99,000kms now approx.
Zero modifications upon arrival. Only mods to date are updated 18" rims.
  • 1 year later...
On 11/3/2017 at 1:59 PM, glenndrayton said:
Hi,
SAU FTW.
  • 1 year later...
  • 1 year later...
That is an unusual spec, if you post the VIN we can double check the original spec in FAST. I've never come across a 33 gtst without HICAS or stereo before. All 33 gtst were designated Type M though.
  • Like 1
7 minutes ago, sin- said:
Is it a ER33? There is also GTS25T Type G. If so there was 22 produced without passenger airbag and with the no audio option.
Yeah bro, we can all read the GTR registry, but its all speculation until he posts the VIN.
It came with hicas, passenger airbag and no sterio just to fix that mistake up.
9 hours ago, JasonMate said:
Iv got a 1996 R33 gts25t series 2 type m that was released off the factory without a stereo, front passenger airbag and hicas. Duno if that's rare i cant find good info on it.
So its a standard R33 gtst, not rare and you learned how to use GTR.registry, so not quite a total waste of oxygen.
Where does this r33 fit in? its a mirror image.
https://en.wheelsage.org/nissan/skyline/r33/44527/pictures/516592
Sorry if this is all stupid questions for this thread but i cant find answers.
Makes sense the dealer fitting different stereo, I didn't think about that.
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
