  • Replies 157
Posted Images
i wouldn't chose either. for low mount turbos for me it's either HKS GT-SS, HKS GT-2530 or Nissan R34 GTR N1 depending on exactly want you want from the car.
2860 :laugh:
Nothing wrong with the garretts...
If they were around before i purchased my GT-SS's, i would have had the garrett copies without blinking an eye
yeh well time will tell how they perform i got the not responsive 2530 type,but hey for bit over 2.5k sounds good to me
i got the gt2860r -5 so ill let ya no how i go... there is a set of 2530 on forums forsale which i would have bought if i had known it earlier
Yep they are mine. :P
Awesome turbo's (as the Mines GT-R has well proven)
Agreed, they are a verry responsive turbo and boy do they come on nice and smooth....
Not from what i saw with Jacks car, having been in it, it was nothing nothing, power power power.
Not something you want if you intend to hit the circuit
:) Now you should go in a car with 2860R's and tell us what you think...
Yes I changed from T517Z's to 2860R's..
Yes I have MUCH more response..
The T517Z's were good for top end, more suited to drag racing, will make good peak power...
No I wouldn't change them for anything.....
No I wouldn't buy HKS items, the price of the Garretts are too good refuse...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
