Fuel Pump Poll
281 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
1. Tomei
2. R33 GTS-T Rb25det 251.rwkw @ 16psi
3. - Bolt-In Pump (took less than 30mins to install)
- Noise level is louder than stock, can not hear it when audio is on, althou you can hear it if u stand next to the boot
- zero starting issue
- no issue with 1/4 tank syndrome
  • Replies 65
Whats the RWKW rating on the Nismo and Tomei Fuel Pumps on an RB25DET??
Cheers
They are 500hp 255 litre pumps, they are the same as the Walbro, but they actually deliver whereas the Walbro [or so they say on these forums] performance is questionable. So you'd theoretically get 300rwkw out of them, then you'd need a surge tank etc anyway, so they could be your supply pump and you could use a bosch or suchlike for the main feed.
i bought a walbro internal one just recently.. Havnt fitted it yet!! for small mods (aim 200kw)
Seems like no one has it??
any reasons lol??
Should i install it??
cheers
no.
better of getting another brand, preferably nismo or tomei if your budget allows it..
walbros are shit.
1. Bosch 040
2. R33 GTS-T Rb25det yet to dyno (237rwkw @ 13psi maxed out my oem pump)
3. - Bolt-In Pump (took less than 45mins to install)
- Noise level is louder than stock, can not hear it inside car, although you can hear it if u stand next to the boot
- zero starting issue, infact the car doesn't hesistate/shudder on take-off now, (when driving slowly.)
- no issue with 1/4 tank syndrome (pump was completely immeressed in fuel on 1/4 tank during installation.)
PS: The trick to no in-cabin noise is to use some extra fuel hose
split it down the length of the hose, unfold and wrap around the pump.
Now hose clamp the cradle to the hose covered section of the pump.
The rubber will absorb most of the vibration and in-turn quiten down the pump.
Hey Nabil, have you tuned/dynoed your car after the Bosch 040 install, ifso what power did it make? from my understanding your using a Sliding Performance highflow?
Cheers
Edited by QRI05E
1. Bosch 040
2. R33 GTS-T Rb25det currently at 247@1bar as clutch was dying. Stock FPR, lines etc..looking at surge tank now. Will update when re-tuned and run at 1.3 bar.
3. - Internal...when I went to install I found the same pump there already...replaced it anyway cos it was out...
- Noise level - I only notice it when u turn on the ignition...however when u listen u can hear it.
- Need to let it prime..u can hear it stop. Then starts first time every time.
- my results speak for themselves...I'm happy for 200 bucks or wotever it cost.
1. Bosch in-tank
2. R32 GTS-4 205rwkw
3. Very noisy, dont know why, but id like to change it because it shits me starting it up and you hear this loud whine coming from it, and start-up sucks, always have to pump accelerator to get it going. Is there anyway to reduce the sound because from what ive heard from all you guys with bosch fuel pumps they seem to be fine, except for mine. So, anyway of reducing sound? Possibly clean it somehow? Has anyone had this problem and had it fixed?
Cheers,
Steve.
any reasons lol??
cheers
Use it. No problems with the walbro in low 200's if it's genuine, it's the copies you have to be careful of.
As for me, pretty much identical setup to nismoid, walbro in tank using stock wiring (easy to fit, came with all mounting hardware needed to fit 32gtst/s13 fuel pump bracket), Bosch 044 external running through surge tank, new 12 gauge wiring to pump plus inline fuse, custom bracket, replaced all original rubber hoses. Audible at idle with the stereo off and full interior fitted, cant hear it if the stereo is on low or the car is moving. Making 288rwkw with stock reg, no fuel surge problems.
Edited by BHDave
*on a side note* 044's can be relativley quiet if mounted properley. ie. good bracket with a think rubber insulator between pump and bracket and insulated between bracket and mounting surface....
i have the rubber between the pump and the bracket and inbetween the bracket and the boot floor,
even if i suspend the pump in the air by holding it it vibrates its ass off and is noisy as,
any ideas how to queiten it up a little(i have rags covering it which helps a little)
cheers
Jeremy
1. Walbro 255 intank
2. Very quiet except when priming, mounted on original bracket with rubber insulator.
3. 200 rwkw
How come no one likes walbro pumps? The fastest Skyline in Sweden runs with walbro pumps (1051 awhp)
  • 3 weeks later...
2. Was absolutely quiet wired directly (without FPCM, as my car was N/A), after rb25det FPCM setup it become noisy at idle (at lower revs). paradox :). I think i will wire it directly again.
3. awkw -- i don`t know. ENR33, 4wd, stock rb25det NEO @0.65 bar so far.
starts better than with stock pump (it started twice with stock pump everytime).
installation was not direct bolt on as i had a kit for Mitsubishi EVO, not for Skyline. There was some issues with fixing the pump on the frame. Buy i think with the right kit it will be ok.
1. Bosch in-tank
Cheers,
Steve.
Same problem here...have an 040 and i'm getting the same problems on start up too...and it gets really noisy on hot days too...
Sorry to go a little bit off topic, but is there anyone on this forum (preferably a trader) that i can p.m about buying a nismo fuel pump?, i was going to order one from negun, i live in new zealand and not many people have had any experience dealing with negun, so i dont want to pay the money then never recieve the pump, i would much rather deal with someone in aussie
If someone could let me know who i could p.m that would be great
Cheers
Cheers
Im in NZ and have brought parts of NENGUN before and they are really good
Would thoroughly reccomend
Oh ok awsome, i actually put a thread on SDU about a week ago but only got 2 replys so far, how long did it take for you to receive the parts after you had payed for them?? and also how good was the communication?? that is my biggest concern.
Cheers mate
Jason,trust Nengun as I have bought some things off them that were quite expensive and always turned up.Including the Nismo pump and am wrapped in it.Quiet,strong flow,and has all wires attached with it`s own frame.Simply pull the old one out and throw it away as the Nismo is complete.
I have 044 which I mounted in my R31 fuel tank on the stock bracket. Its quite noisy. I'm not sure if its my 044 which is at fault if its vibrating the bracket and causing the noise. You can hear it more from outside of the car than you can from inside though. It doesn't really bother me.
I never used a surge tank and it would surge at 1/3 tank under acceleration. I fixed this with my dog food surge can mod. Some say dodgy, I say less dodgy than an expensive, illegal, smelly and space taking surge tank in the boot. It works fine I have no surge issues at all now.
Some shitty pics.
Edited by DennisRB30
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
