Yes i realise this - but as i said, just once you get pinned and it's all over really.
The EPA aren't idiots, they know probably 95% of people are putting a massively restrictive muffler/baffle onto their exhausts etc etc.
So it's only a matter of time before they clamp down on that as well.
I think so far in this car i have been epad 3 times. 1 full test and 2 noise tests. The guy i know that does the EPA noise test puts that i have a mid muffler on the diagram so the epa dont bother me about it later.
But on a different question here, what is the distinct line between a defect and an epa?
E.g. On a defect notice they will write that a atmo bov is a defect on the vehicle... but it technically is an EPA issue. I was under the impression that a defect is given for a car that is un road worthy. Why do they pick up things that have to do with EPA and put it on a defect??
Just an update, got my defect cleared the other week, took the RWC to Vicroads and they just cleared it.
I thought that they inspect the vehicle for major defects, but they did not. Too easy.
  • 1 month later...
quick query. i own a 94 32gtr and i recently recieved my first full EPA notice, however;
when the police officers pulled me over and found out that it was a "GTR skyline" according to the coppa, he told me my pods were illegal, even though they are dry pods. my intercooler is illegal, even though it is an R33 GTR intercooler (steel end tanks rather than plastic on the 32s) and my bovs were illegal. He also pointed out that my exhaust was rather loud (which it is, fair enough).
So now I have to go get the test even though the legislation clearly states 2 of my intake modifications are legal? So if I put a stock exhaust or have my current one modified to suit and put stock recirculation valves in I should pass?
How is it though the cops can report you to the EPA for modifications that they say are legal? I rang the EPA and they listed the modifications recorded which were;
aftermarket pods
aftermarket intercooler
aftermarket bovs
and aftermarket exhaust.
Is there anyway in the future if I am pulled over of informing the police, shy of pulling out the GTR service manual, that my modifications are indeed legal.
any help greatly appreciated guys
regards,
Gabbo
Police can report you for EPA regardless of whether or not you are actually in violation. They don't care, there is no punishment/reprimand system in place etc etc.
So they can report you for anything based on suspicion, not fact.
That's how the law is, so they get away with it.
I will take the next cop that reports me to court, im sick of it :D
I will take the next cop that reports me to court, im sick of it :rant:
Has anyone ever thought about legal action against the police for continual harrasment? or a group action against the police for continual harrasment? its a pretty well known fact the import scene is targeted over say the v8 scene. i wonder if the xr6turbo forums have a threat purely devoted to EPA dramas.
anyway, got any advice for us dude, your help would be really appreciated
Im running out of ideas to get air into my standard airbox as i cant fit the snorkle in due to fmic piping. Getting a vented cf bonnet which will have a air intake feed for a pod. Was wondering if its classified as a "intake mod" if i cut a hole in the top of the standard airbox and fill it up with thin mesh so that the air can get in from the top?
Cheers
Cheers
Change the FMIC piping. Keep the snorkel.
Cheers.
  • 3 weeks later...
Cheers
according to a previous post, modifying the stock air box is considered an intake mod.
Has anyone ever thought about legal action against the police for continual harassment? or a group action against the police for continual harassment? its a pretty well known fact the import scene is targeted over say the v8 scene. i wonder if the xr6turbo forums have a threat purely devoted to EPA dramas.
not sure what your car looks like but if it draws attention from the average person, than that's a start. change the car to looks more stock like, have an exhaust closer to the 90db limit, have a pumped back BOV ect.
other than those ideas, you are outta luck unless you move suburbs or change the areas you drive through.
just to let you boys know, its possible to pass a full EPA with a full turbo back 3" system. I JUST DID! @86db.
i have a 3" Xforce cat, middle muffler and rear Fujitsubo Jasma muffler - all 3" piping. - i also passed my 180sx with full 3" system from turbo until rear muffler- rear muffler was 3" to 2" especially made up to be like stock. @87db.
....this might help people save money n time :)
....this might help people save money n time :D
86db exhaust on the stagea is legal too... Racepace do 3.5" legal systems, that flow rather well from what has been said by members on this board...
Keep snorkel same, when modifying FMIC piping I wonder if changing the pipe off the TB to tight bend would be argued to be a separate mod, or part of the FMIC+piping mod :)
Got full epa from pettet, yay! Have a 3" kaikimoto system wif a high flow catco cat. Now i know the exhaust is "Jasma"approved which means 92dba Yes? Which i can swap out for something i get made up. I was just wondering about the emissions. Do i have to worry about my FMIC? Will that play with the emissions? and BTW its a return style so wont get dicked for that
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
