  • 2 months later...
Would a ding like the one on this car prevent roadworthiness? The one on the back door most specifically, the paint would probably buff off.
cp5324997492350916733.jpg?height=700&asp
Edited by bucket_boy101
  • 1 month later...
  • 3 months later...
I've just bought an R34 GTT and I'm looking for some original rubber brake and clutch pedal covers for a roadworthy. I know in the past aftermarket bolt-ons have been denied, and I don't particularly want to pay $150ish dollars for genuine GTR ones. Any help would be much appreciated.
I spoke to the mechanic today who will be doing the roadworthy and he said bolt on type of pedal covers would need to be bolted THROUGH the pedals, not bolted on using brackets as most aftermarket kits have, or alternatively, grip tape/skateboard deck tape is acceptable, as long as the pedal has a grippy surface it will pass. So I spent $5 at a bike shop on a 90mm x 500mm strip of scooter deck tape. I'll have enough left over to re-cover both pedals 5 times over. He is also happy with coilovers as long as they are a quality brand (mine are Teins) and not a backyard job. Car is booked in for Monday, happy days!
  • 4 months later...
Got a question for everyone, i was in a quiet carpark tonight and was revving the car stationary a bit (its fairly loud) and a unmarked ford transit van pulls out of nowhere with 6 cops in it, two come out and say what the hell are you doing..
long story short they didn't check my license or anything.. just said your car dosnt sound normal I'm going to take your rego down and pass it on to a highway patrol to check over your car so expect a letter in the mail !!
Do you guys think the cop was bluffing? does a why patrol come to your house to check your car or? any help will be greatly appreciated.
there is nothing stoping a cop coming around and checking your car. strange if they had that much of a concern that they didnt get the HWY Patrol car to come there on the spot. but i suppose all you can do is wait now.
You'll most likely get an EPA notice in the mail, organised BY hwy patrol courtesy of him forwarding your details to them. Which means going to a noise test. Unless he got lazy later on or forgot about it, you'll get a notice.
I was in a quiet carpark tonight and was revving the car stationary a bit (its fairly loud) and a unmarked ford transit van pulls out of nowhere with 6 cops in it, two come out and say what the hell are you doing..
I would have said the same thing... :P
  • 3 weeks later...
Ok, so I tried to get a roadworthy today, and it failed because when you put the headlights onto high beam, the low beam lights switch off.
According to Vic RW standards, the low beams need to stay on when you're on high beam.
AFAIK, this is normal for the car, but the workshop guy said absolutely no room for negotiation on this.
WTF? Anyone had any experience with this?
uwot?
Skylines (and lots of cars) do this from factory... as you pull the stalk towards you, highbeams come on and then (less than a mm later) lowbeams go off...
I assume to limit power draw or overheating of the headlight casings?
They got complianced just fine like this...
I'd ask him to point out where in the Vicroads regulations it specifies headlights and high beams must come on at the same time. Nothing in VI26 stating that at all.
https://www.google.com/url?q=https://www.vicroads.vic.gov.au/~/media/files/documents/safety-and-road-rules/vsi26_1212_web.ashx%3Fla%3Den&sa=U&ei=a8xlVOGCCIO0uASmn4H4Dw&ved=0CAYQFjAA&client=internal-uds-cse&usg=AFQjCNGnCFP--oDZ6hARnPy2LHeNtUDf2Q
Nothing in ADR 46/00 about headlight/high beam coming on at the same time either if you wanted more proof that dude is talking out of his arse :P
http://www.comlaw.gov.au/Details/F2006L02294
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
