That is rubbish economy mate, what do you get if you do the same driving on 98 (I believe you have a switch so you can manually select the fuel you are using, yes?)
that would make it $60 for 600kms
still cheaper than a full tank of 98 for about $90 to get you about 500kms..
Still cheaper, yes... but I'd be stopping every day for another tank of LPG!
Where you getting your 98 from? Last time I filled the tank (last week) is cost me $108 :dry:
but that was 620kms ago (the light just came on this morning, so I should get at least another 80kms out of it :P)
oh yeh your highway trip rights. see what you mean.
lol $108?? it hasnt been THAT long since I put fuel right?
but you get amazing economy lol
Non-highway driving kills me, all my driving is stop start short trips of 2-10km, or hills driving with no option to maintain a consistent speed. Whats 'economy' >_< Id say im still running quite rich mind you, almost ready for a tune - getting tired of seeing a nice ploom of black in my rear view mirror when I take off :whistling:
yeh this is around what i was putting last. cheapest i saw i think was 1.37
Wow, at that price I'd bring back a tanker! Up here our 91 Octane E10 is 5c/lt dearer than that.
Cam - yeah the economy is pretty bad.
On 98 I get around 14Lp/100km around town. 10Lp/100km on the freeway.
I expected probably a max 15% increase in consumption but looks like I've gone to 30% in consumption...so while the price/km ratio is still a shitloads better then 98, its definately not delivery what was advertised by the ALPGW mob :domokun:
I wonder if there's a freaking leak in the system...cos it feels like it!
yeh. if its in cold start, car runs richer.
cold start is caused by the coolant temp sensor reading cold.
im sure you know it - but its for cold morning starts etc..
Ah, that makes sense!
I'll see if this 02 sensor does anything for me then go from there, I'm happy to accept 14-15L/100km with all round driving, but 20+ is just wrong.
yeh my o2 sensor was my problem.
plugged in it would run so poorly that it would pop on idle. im guessing near about flooding, and completely missfiring 3000rpm +
unplugged it was fine.
so i ditched it and tuned..
I get about 400kms a tank since i got the car back to Adelaide. I think that works out to about 20l/100, or 5km/l for those with the leaf!
The novelty of the turbo hasnt worn off yet though, so there has been a bit of fun...
Im running the car on 100 octane e10, i have a servo down the road and there are a fair few in SA. Last night cost me $1.50/l.
Latest road trip recorded the following fuel economy. Loaded with 4 people and all luggage.
Sydney - Canberra (towing a 7 x 4 box trailer with 4 bikes mounted on top) = 15L/100km
Canberra - Albury (via The Alpine Way) = 14.2L/100km.
Albury (2 days commuting) - Goulburn = 11.7L/100km
Goulburn - Ryde = 9.2L/100km
Pretty happy with results. :)
That's excellent Andy - each leg was better than the one before. Did you ditch the trailer for the return, drive more economical on the way home or did the ECU learn something new? :)
Ditched the trailer at Canberra. A mate took it home as I was heading on to Albury.
Went from from heavy towing load, to mountain roads to Freeway... that was the difference.
I'm getting 14L/100KM with my 250RS.
Running on Caltex 95, 50/50 Norm/Sports Mode
Can get higher open road driving, like I got from Hamilton to Wellington(535km) then back half way on a tank, around town is a shocker though.
Hmm... thought I was doing well since concentrating on driving economically (not necessarily slow).
Filled up last night - 70.4L with 749kms on the ODO :)
Still cost me $116 to fill up though :pirate:
WTF. Man, thats awesome economy!
I have 550km on the ODO and the light has just come on... and this tank includes a trip down the coast on highways.
I find out l/100km tomorrow when I fill up.
Seems pretty shit, even if I get 75 litres in, it will still be around 13.5 L/100km
Don't want to know what my fuel consumption is now I'm running 240kw with a 3076. Still needs further tuning tho, thanks to a boost leak ... which will affect the fuel economy also. :(
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
