mine must have something not really running right cause i only get 270-300 out of a tank of 98 octane, mind you it's all stop start driving and my right foot weighs a tonne so i dunno. Front mount, 3 inch cat back, and a mushroom shaped filter. Any comments??
change the filter, not the best flow, but the worst filtration
also, check your o2 sensor (or have it checked), just find someone with a consult cable
Air Filter Shoot Out.pdf
definitely something wrong, check for boost leaks and go from there
o2 sensor will cause bad fuel consumption but not that bad
could also be leaking injectors or even bigger injectors (jap fitted) that just run with the stock ecu (but i doubt this)
It's got a PFC but I don't know what the tune is like.
To be honest, I suspect there may be a fuel leak. The turbo whine sounds very, very different to my R33 and I have a feeling what I can hear is actually compressed air escaping.
The guy who owned it before me said a few issues arose after he put the FMIC on it. It fouls plugs like a bastardo. The ones in it have done about 150ks and it's already starting to struggle at full throttle. I also noticed today that with the eboost turned right down, it's struggling to achieve 6psi of boost. It was comfortably boosting to 7psi which is stock.
sounds like you have a few issues there
you'd smell a fuel leak
prob a boost leak
then get a touch up tune and make sure they re-activate the o2 sensor
In my rx m35 driving home from work through hills and lights screen is telling me between 7.9/9.2km/l. so bout 11 - 13.2 lts per 100km. Just driving normal keeping of boost as much as possible. Cant help up hills though. Not too bad I think. For a stock as a rock with only k&n panel filter
had a quick look at afm appears the clippy bit on the plug is broken so nothing actually holding the plug in tight, probably be the problem. Now to find a new plug to wire in, none on ebay atm tho.
i just did 553kms in my m35 on e10 with some mods done and i also had a play as well.not too bad i thought
What mods have you done out of curiosity?
That's pretty good economy. Was it mainly highway driving or a bit of 'peak hour' thrown in there?
Even with my leaden clog, that's fairly achievable. How do you find it on e10? I tried running our daily on it; but the car just didn't agree with it, so I never even tried the Stagea.
Over the last few days did a return trip to Canberra. Since I last posted my economy on the last trip of 11.3L/100km and 9.3L/100km I have made a couple of mods.
I have installed a new larger suction pipe and installed Scotts special turbo actuator that has an additional spring fitted to it to keep the waste gate closed on low rpm and hold boost to high rpm.
This last trip got 11.3L/100km on the Sydney - Canberra leg and included 5 days commuting in Canberra.
Return trip from Goulburn - West Ryde where I filled up was 9.0L/100km. I saw a low of 8.6L/100km before I got into Sydney traffic.
I have an Exhaust Gas Temperature probe fitted and can see with these mods that car is running a little leaner on cruise with temps ranging from 400 - 700 degrees.
Nice one Andy. Quality info. Like the temp probe in the zorst!
Are you running a scotty special dump too, or factory?
Not a scott dump but a Westside one that was modeled off a Dolphin one that Craig bought.
I have a full 3 inch exhaust from turbo back.
I've never even seen 100 octane e10 in my locale, only povvo 91 octane.
And it's shite.
All the United servos in SA have E10 100oct. While I was there today I noticed they have now dropped boost 98 e10 and replaced it with e85!!! Going to fill the jerry cans tonight to run the 180SX on it, hello 300 + rwkw :) and all on 18psi with a gt2871r!
Edited by slippylotion
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
