M35 averaged 9.69L/100km in the last week. Lowest was 8.00L/100km between Mildura and Wagga Wagga. That includes 3 days of city driving around Canberra so I'm pretty happy with that. Return trip was a bit thirstier due to head wind, more overtaking and.. urgency.
8L/100K is impressive. You running E10 or something?
on 98 i got 606 out of a tank,
it was a mix of city & highway,the mods i have are high flow turbo(stockish) high flow cat hdi inter-cooler and a k&n high flow panel air filter.ill be doing the same trip this weekend and ill try some 98 and see what i get this time around.
Screw you guys, I'm averaging 14.78L/100kms, according to the app on my phone. Best run was 12.37L/100, worst was 18.07L/00, but I think that included the drag day @ WSID.
Then again, I don't drive for economy.
+1 to this , I enjoy 2nd and 3rd gear too much.
I can understand C34 owners getting upset when M35 owners rub the C34 noses in our glorious 5 speed auto box, more leg room, less cabin noise, better weight distribution, newer technology, better handling, better interior, better ride, more room in the back, better stock power and better fuel economy....... :devil:
Most of what you said was true but I gotta say you can keep your "glorious" 5 speed auto gearbox. Its like this :- the VQ25DET is fantastic, but the laggy gearbox will keep you from really enjoying it.
I've owned both C34 and M35 - am back in a S2 C34 now, and my summary is as follows:
The ONE thing wrong with the M35 = drive-by-wire. I'm not sure if the drive-by-wire was the cause of the problem, but the gearbox was laggy as hell, and for me it really hurt the car.
Yes, the M35 is newer, and better in almost every way, except that in a stock for stock comparison, the C34 auto & throttle is WAY more responsive.
When I sold my M35 I stupidly bought a 2007 Ford wagon - what a heap of junk! After learning the hard way, I sold it after 3 weeks and returned to a stagea, but went for a C34 due to the lower price and lower running costs.
Both cars are great to own and drive - the C34 is more responsive and more "raw" (I think you feel more connected with the car), while the M35 is more comfortable and more luxurious (while being actually faster and handling better).
While on the topic of fuel economy, the difference between the two cars isn't that great:
My M35 got ~12L/100km city & 9.5L/100km highway
My C34 gets ~12.5L/100km city & 10.5L/100km highway
The M35 has different gear/diff ratios which helps a lot on the highway (the extra gear does make sense here).
Always get 400-450k's to a tank before the fuel light comes on in our S2 C34 with Neo RB25t. However, last tank we only managed 350k's before fuel light came on.... any ideas why? For the first time ever the Engine warning light came on too.
dead o2 sensor
or dying coilpacks
or boost leak
I'm at nearly 400ks for this current tank and it's getting damn close to fuel light time. I reckon I'll just nick 400 when it comes on. I would expect better for the driving I do (works out to be around 15l/100ks).
Mostly suburb driving. Still haven't figured out what my crappy miss is. Starting to lean towards coil packs. Might try gapping my plugs down and see if that helps a bit.
how do you test the o2 sensor?? i have been getting 350k's per tank for awhile now.
The best way to test them is is go here - http://www.skylinesaustralia.com/forums/topic/135194-ntk-nissan-lambda-sensors-o2-sensors/page__p__2513840__hl__sensor__fromsearch__1#entry2513840 - buy a new one and replace it.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
