Guys and Gals,
I thought I'd chuck together a thread where everyone can post up the brake pads they have used and what they thought of them. I'll try and keep a summary up in this 1st thread as a quick glance resource. I'll list the pads as people post them up under three headings as either track only pads, track/street pads or steet only pads. For the summary I'll do a simple :) next to the pad name if people like them or a :) followed by a reason if people don't like them. Also if people can list where they got the pads from that would be great too. If you want anything else added let me know.
Track Pads
EBC Green :) (poor performance and taper wear)
EBC Yellow - OK but not as good as DS3000's
Ferodo DS3000 :)smile.gifsmile.gif
Ferodo DS2500 :) (rears) :) (crumble with hard use)
Performance Friction Carbon Metallic :P
SBS Dual Carbon :)
Track/Street Pads
Bendix Ultiamtes smile.gifsmile.gif (Light track work)
EBC Green - OK But not as good as DS2500's
SBS Ceramic Carbon :)
Street Pads
https://www.sau.com.au/forums/topic/169972-brake-pads-users-ratings-guide/
I'll start my own thread then :P
I currently use in my GT-R Ferodo DS3000 pads in the fronts and DS2500 in the rears. I think they are great. Can get a little noisy if I haven't done much hard driving but after one good session become quiet again rather quickly. For me I love the progressive bite - but they will bite hard given a firm press. I get mine from John @ UAS and would highly recommend them for a track set-up.
cool.
ds3000 good feel ,consistant, used on v8 brutes. the discs crack before they break up.
ds2500 pretty average not very bity. and crumble with hard use. (since 3000 came along) but once warm ok.
ebc green. garbage and extreem taperd ware.
sbc ceramic carbon. awsome street/track pad. long lasting and dont overheat the disc. my pic for steet/track
sbc duel carbon. very good aswell. more track orientated. long lasting and take an awfull lot of heat. (targa favorite)
performance friction carbon metalic.
omg insane pad. so easy to use and instant pedal responce. my pic of the list. but due to the fact that they work so well you cant tell your overheating the discs. cos they feel the same from warm to a orange hot disc. (as used in most top level motorsport. nascar,v8 supercars etc etc)
bendix ultimate,ferodo formula,metal kings etc etc. pretty crap and good for going up to the shops.
i haved used all these pads in my gtr with 355mm rotors and brembo f40's (38,44mm pistons) and im hard on brakes. once you get good brakes you seem to explore there limmits hehe
I've been using factory pads so far and they are working fine, no fad. Have just brought some new Bendix Street Road Track to see if I can shortern the distance down a bit. But very impressed with factory brakes!
This topic is a good idea, pity about the lack of response.
Anyway, I've had good results when doing sprints at QR, Sprint circuit, with Bendix Ultimates. Great bang for buck but not a race pad. So thinking of EBC Yellow stuffs, which are supposed to work cold too. My big concern is rotor wear, but seeing noone uses them.............
Using RB74 front and rear pads. Stock rear dics and 4000 series (non-slotted) fronts on R33 GTSt.
Good pad, warm up in one average stop first thing in the morning, can be very noisy if you don't grease the shims properly. Definately better than Nissan pads that seem to leave material on the disc after hard driving (makes discs feel temporarily warped)
Been used around QR and seemed fine and dandy. But I've only got 170rwkw.
my 2c - some of this is second hand tho
DS3000s - high friction 0.62 so very grippy - works well at high temp - tough on rotors (maybe only at low temps tho) - manufacturer says "NOT suitable for road use", presumably because of the rotor wear issue
EBC Yellows - quite like DS3000 - similar price so you might as well use the better DS3000s
DS2500s - med friction 0.5 so not as grippy as DS3000s - dont eat rotors - good for track and street
EBC Reds - quite like DS2500s - similar price so you might as well use the better wearing DS2500s
EBC greens - med friction 0.55 - everyone says they're crap but they worked ok for me on street and light track work
You should use pads of the same friction coefficient front and rear unless you want to change the brake bias.
what are people's thoughts on the endless sss or ssm pads? looking to get these sometime soon. 90% street work, the rest on twisties or track.
Recommended...
I've been running the SSS pads for a lil while now. For what you've said you'll be using them for - low noise, low dust and still good after 4 laps of Sandown...
In my time with the 34 I used:
Endless Euro-X (front) and Endless NA-R (rear)
Great for track, no fade after 5 laps, but poor pedal feel and noisy when cold so not the best for street. These are now old parts replaced by newer Endless pads.
Bendix Heavy Duty (front)
Put in as a stop-gap measure cos my front pads were too low before a track day. These pads were crap for my application, poor pedal feel on the street, dusty, wore quickly, faded after 2 laps but didn't go away completely.
Queensland Friction Materials (QFM) A1.RM (front+rear)
Good compromise pad for those on a budget. Good street feel from cold. Good performance on the track with only a slight fade on lap 5. Kind to rotors, low on dust, and cheap, ~$120 per pair (about 1/3 the price I paid for Endless).
I should mention what really helped was also:
- decent fluid (Endless fluid or Motul Factory Line)
- decent rotors (basic upgrade to DBA/RDA slotted rotors of stock diameters)
- cooling (cutting away the guard plastic in front of the front wheels to allow airflow, removal of dust plates)
- braided lines front and rear
- master cylinder brace
- proper bleeding procedure
Im using the SSS 500 deg front and 380 deg for rear for almost 1 year. Been on a lot of twisties all year round and does mostly street. No noise at all and quite low brake dust with plenty of bite. Though some ppl use them find them to be squeky on low speed though i haven't experienced this before.
Any price is acceptable and gonna change the pad in 2 months time.
Dunno how I missed this thead til now.
Snowy, what's the reasoning behind DS3000 front and DS2500 rear?
I have used:
Bendix advance - as dave says, fine for going up to the shops.
Bendix Ultimates - Nice and bitey, better than advance, chew through rotors like a fat man munching down on an old twix, wear out quickly, dusty, can be noisy.
Ferrodo DS2500 - long wearing, heat rotors pretty badly making it very easy to crack them, don't chew them though, cheap for performance pads, can be used on the street although an emergency stop when dead cold wont be too great, don't need much heat to negate this at all though.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
