mate can you please get me the part numbers for:
- R33 GTST Series 2 Air Flow Meter
- R34 GTT Air Flow Meter
greatly appreciated coz I need to know whether these are the same, as I lost my original AFM and have the R33 S2 in there now. Cheers
i can tell you that they are the the same. i think the part NO. is 22680 31U00 i think it may have sup maybe 22680 31U05
OK FAST gurus I need some help!
Vin BNR32-014400. Illustration 401-B-2
In the top left corner it shows the N1 brake ducts that bolt onto the caster rod. I thought these were one of those n1 myths until I stumbled across this section tonight
Anyway....I can't see a single part number for the whole assembly (ie everything you need to bolt it onto caster rod. What part numbers do I need?
My viscous engine fan won't turn off, so is it shagged?
can anyone help and advise what the part number is for a '91 GTR?
thanks
just to check u do mean the viscous fan, right the one that bolts to the water pump if that is not turning u do have a major problem. i can't not help with the part number at the moment because i am on holidays an don't have access to the nissan fast system. will let u know the part number when i can
don't know if this will help u but don't have access to the fast system at the moment. try looking with the brake piping i had to find a similar brake duct for a R34 GTR and that is where i found it
There is no ASSY part number. You need a R32 N1 VIN number to even get the part number for the guides out of fast. I just so happened to find one though.
You need part numbers:
41182-05U00 GUIDE-AIR BRAKE RH
41183-05U00 GUIDE-AIR BRAKE LH
41184-37P00 CLIP-AIR GUIDE x 4
08918-5082A NUT FLANGE x 4
08363-8302D SCREW-MACHINE x 4
I dare say you could get nuts and bolts yourself and skip the Nissan ones.
Looked there but alas nothing on 32 N1.
Hi part no for R34 GTR welsh plug please
also PM'ed you another query on R34 GTR gasket nos for intake plenim and throttle body, sorry if should have used this post...regards.
BNR34 WELCH plugs come in two flavours:
01648-00121 PLUG WELCH - There are 7 of these on an R34 GTR
11051-D0101 PLUG WELCH - There are 3 of these on an R34 GTR
For the gaskets, if you're doing a lot of gaskets you want the engine repair kit: 10101-24U28 or the gaskets by themselves are:
16175-05U70 - GASKET THROTTLE CHAMBER - There's 6 of these
14035-05U10 - GASKET INTAKE MANIFOLD, B - There's 1 of these
yeah this bad boy.
the biggie that hangs off the front of the motor ;)
thanks to anyone who can grab it :)
thanks
R32 GTR Coupling Assy - 21082-05U00
looking at $450 - $470 from Melb Warehouse :rolleyes:
On the off chance you haven't forgotten.
Am trying to track down the rear Brembo callipers from the 33 GT-R. Any chance of part number/ price?
R33 GTR LH Caliper: 44011-24U00 ~$2700
R33 GTR RH Caliper: 44001-24U00 ~$2600
Thats exspensive!! lol prob Japan too!!
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
