You have full boost by 3500rpm ;)
Same turbo on a rb2530 is going to be a lot of tyre shredding fun :P I was told full boost (20psi) by 3400rpm, but it may be even earlier.
Any dyno graphs?
No dyno graphs yet. I will post them as soon as they are available. The next motor will either be a fully built RB25 or a RB26 high decked to a RB28 with a 3540 or similar. What ever will rev hard and give me 400ish.
  • Replies 89
Posted Images
Defanitly not taking it to QLD. Staying in Melbs!
Cheese!!! Looking sexy, almost as sexy as yourself... (almost) If you need me to go around and umm... start her up... let us know! Promise I won't poke any holes! :thumbsup:
  • 1 year later...
Thought I would pull out the defibrillator on this post mainly for Brisby as he wanted to see pics.
Recent modifications are....
Alcon brakes
Tinted perspex windows
New bonnet
Vented front guards
New boot
R34 rear end and new suspension arms and shocks
Rear diffuser
Replaced fuel cell with stock fuel tank
Changed rear wheels from 12 inch to 10.5 inch
Aero catches for boot and bonnet
Big thanks to Freddy at Top Stage for the new body work and Mick from Micolour for the excellent paint and tidy up.
Looking to hit Sandown on 25th April to see whether any of it helped lol.
Next on the list is a BIG wing and FRP doors then apart from playing around with the set up its finished.
post-917-1239707631_thumb.jpg post-917-1239707676_thumb.jpg post-917-1239707691_thumb.jpg post-917-1239707719_thumb.jpg post-917-1239707728_thumb.jpg post-917-1239707742_thumb.jpg post-917-1239707757_thumb.jpg post-917-1239707772_thumb.jpg post-917-1239707790_thumb.jpg post-917-1239707807_thumb.jpg post-917-1239707821_thumb.jpg post-917-1239707843_thumb.jpg post-917-1239707857_thumb.jpg post-917-1239707872_thumb.jpg post-917-1239707881_thumb.jpg
do you just have a rear diffuser, or do you also have a front splitter and a flat underbody?
btw. Car is SEX :P
There is a front splitter of sorts and now a rear diffuser. The front splitter is just a sheet of aluminium under the front bar. W plan on making a more areo dynamic one out of carbon in the future.
Exciting.
I wanted somthing that was like diving a 300kw in the wet and thats prety much what its like. You have to think twice before touching the right peddle in any gear apart from 5th lol. But it should be a bit eaiser to drive now which hopefully means faster.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
