I haven't had a chance to contact Nissan and probably won't tomorrow either. Any chance you could give them a call?
It is called a Powerbox (part No 16500X) needs the same stud the secures the current cover to hold it into place. If you can do this, can you also check the price of the stud (16528F)
Cheers
Andy
Hi Andy,
Sorry about the delay I didn't get time before I went to Phillip Island....you sitting down???the price is $180 inc GST for part number 16500x....the other lug looks like the same ones as we are already using so I didn't bother...the wait is 2 to 3 weeks.
P.S. I think I'll make mine.
https://www.sau.com.au/forums/topic/185569-m35-info/page/8/#findComment-3710227
Hi Andy,
I think I will make mine also. I have a few idea's about doing this. I will let you know how I go.
Thanks for checking.
Cheers
Andy
https://www.sau.com.au/forums/topic/185569-m35-info/page/8/#findComment-3710280
hey anyone got any more news on the sat nav conversion.
I emailed them last week trying to get an idea of when it may be available but they were thinking that because not a lot of people on the forum have shwn interest that it may not be commercially viable for them. I sent them further infortation to explain that there is a much bigger market beyond this forum. I have not heard back in the last 7 days since this email was sent. I am hoing they are just away and will come back to me soon about whan and how it will be possible.
As soon as I have some more information I will post it.
Cheers
Andy
https://www.sau.com.au/forums/topic/185569-m35-info/page/8/#findComment-3721336
Hi Andy,
I finished the home made cold intake today. I will post some pics tomorrow. A little crude but definatley effective. And ony cost about $20.
Cheers
andy
https://www.sau.com.au/forums/topic/185569-m35-info/page/8/#findComment-3722463
Ok, I rang the guy. Half an hour on the phone :D
To cut the long story short - they do (or can do) alot. Translating to English is not the main thing, they are aiming for proper GPS solution.
They need to know if there are any Nissans with built-in Nissan GPS systems in Australia - basically they want to be able to utilise existing Nissan maps; they are not exactly the same as Japanese, but they are close enough and could be converted to Japanese format.
As a prove, I've been offered a "demo" - they can prepare something partially translated and if someone in Perth is brave enough to be a tester, they will provide us with software and instructions and we'll be able to install it.
My understanding it that at this stage they are not giving away complete solution, they are still working in it (they call it "dealer version" :D )
Good and bad news for S1/S2 owners - they do not have anything for CD-based systems as it is an old system but if we find about 50 units, they may consider spending time and money and do something for us.
I believe that Andy has got much more info...
Hi Guys ,sorry to but in but i have a set of discs from england that i bought trying to sort out our problem, Im in Melbourne outer east, If i can be any help let me now.
I got the radio and TV the only thing left is the gps.
https://www.sau.com.au/forums/topic/185569-m35-info/page/8/#findComment-3722652
Hi Dennis
The disc's you have convert the japanese menu's to english?
Cheers
Andy
https://www.sau.com.au/forums/topic/185569-m35-info/page/8/#findComment-3722696
Cheers
andy
look forward to seeing it....I've started.....just need to finish it.
https://www.sau.com.au/forums/topic/185569-m35-info/page/8/#findComment-3723837
I made my own cold air intake for the M35 today like fitted to the V35. Not sure what sort of power gain is avieved by this mod but it feels better higher in the rev range (not so breathless) and certainly sounds a bit better.
I just need to fit some foam infront of the air box (see arrow on 2nd photo) to avoid any hot air creeping into the air box.
It is made of L shape extruded plastic from Bunnings and automotive seal bought from Clark Rubber. Cost, less than $20 and a bit of time.
Edited by andy65b
https://www.sau.com.au/forums/topic/185569-m35-info/page/8/#findComment-3724314
Looks good mate, and the price is great....
https://www.sau.com.au/forums/topic/185569-m35-info/page/8/#findComment-3724345
how did you get the TV working. i'd be interested to get mine working. let me know how you went about it and how much it cost.
thanks
https://www.sau.com.au/forums/topic/185569-m35-info/page/8/#findComment-3725077
thanks
Have a look at the attached link. This unit should work with the M35. Appears to be perfectly compatible.
http://www.skylinesaustralia.com/forums/St....html&hl=tv,
Cheers
Andy
https://www.sau.com.au/forums/topic/185569-m35-info/page/8/#findComment-3725386
a long shot here but has anyone got any info on converting an m35 into manual. is there a compatible gearbox?
just throwing it out there because i'd love to do it if its possible and not outrageously expensive.
cheers
Apparently the 6 speed manual from the Autech 350s Stagea will fit straight in, but dont quote me on it. If it does it would of course be nicer to have the 6 speed....
https://www.sau.com.au/forums/topic/185569-m35-info/page/8/#findComment-3725495
Cheers
Andy
I can confirm that the TV works well in the M35 the only difference is some of the wiring colours in the connector.
One thing I noticed is that there is a little engine noise in the system but its not too bad.
https://www.sau.com.au/forums/topic/185569-m35-info/page/8/#findComment-3725937
how hard was the install or does it just slip right in. how much was it all up and did you need any adapters as well.
https://www.sau.com.au/forums/topic/185569-m35-info/page/8/#findComment-3726209
How is the reception ? I also noticed some very slight noise, was thinking to clean that up with a 'noise filter' on the power wires. Ive got 2 from an old pioneer analogue car tv tuner which should do the job. Probably these are a must for all add-on audio and video receivers.
Simon
https://www.sau.com.au/forums/topic/185569-m35-info/page/8/#findComment-3726764
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
