$560 for the box
$95 for the harness
Both delivered from Nengun. I have one in my car man. Seems to work a treat.
Would be a good idea to upgrade but its like changing the stock bov's on a gtr, no required.
If my ignition wasn't up for the task my tuner would have told me from the onset.
I'm only running 405awkw :) maybe when pushing monstrous power this mod is needed on the gtr
i never really thought about that - are you referring to the ignition box?
how much are they approx?
Marko I run the HKS Twin Power amplifier and was running Splitfires with no drama until new engine dropped in. I was always happy with the Splitfires performance.
We ran 2 new sets tuning the new engine and always at around 8200rpm we started getting misfire so went back to standard and sweet as. Engines putting out around the 450kw mark and still has to have final power check.
The Jap guys reckon the Splitfires are a great performance upgrade but when starting to push over 600ps upwards they tend to misfire. The HKS guys were always umming and aahing when I chose Splitfires over the standard coils. I'm not knocking them as they are a great product but they have their limitations.
Most big power engines/race engine in Japan are using standard coil packs or the Okada Project Plasma Directs
http://www.okadaprojects.com/usa/products_direct.htm
Either one new will rip a new hole where the sun dont shine !
i wondered about the Okada Project Plasma Directs as i saw them on rhdjapan website when i ordered my splitfires BUT the price was 3 times that of the splitfires @ $1450 for the set...anyway, my tuner recommended splitfires so i stuck with them :unsure:
liek u say as well - any new coil pack will be better than 20year old factory coils!
The Splitfires are a great coil pack but talking to alot of tuners in Japan they find they have limits with big power applications.
My old OEM's were sweet as where the Splitfires were misfiring.
Ended up getting a new set at a good discount through friend at Nissan, still hurt the pocket and thats why I bought the Splitfires in the first place.
The Okada's ..well love to get them but the price tag is a bit too much on the ouch side.
Agreed, any of the big HP RB's we have had through had the same issues, chuck in a set of new OEM coil packs and a HKS twin power and the sky was the limit.
Rewire your coilpacks straight to battery with a relay and ignition onto the old wiring with an inline fuse should stop a lot of the "coilpack melting" episodes people seem to be having :P
Rewire your coilpacks straight to battery with a relay and ignition onto the old wiring with an inline fuse should stop a lot of the "coilpack melting" episodes people seem to be having :P will also make the ride a whole lot smoother.
Bought JJR coilpacks for a R33 S2 and they were never right but now are misfirring badly at high boost and guess what? It has been about 15 months after purchase so now im fooked... Should I try to gap the plugs to 0.7mm? I currently have BCPR7ES gapped to 0.8mm and its missfiring under high boost. These coilpacks are pieces of shit seriously!
Edited by da spike
why don't you call the guys you bought the pieces of shit of and talk to them before slagging them off. Have you tried any other coils? Do you know coils are even you problem? They obviously are not the fix to every single missfire problem
What do people (who know) think of these 'direct from battery' wiring setups?
Any advantage or disadvantage to these?
  • 4 weeks later...
had my yellow jackets for over 5000kms, 2 track days and a motorkhana. pulled them out the other day for inspection and no signs of wear at all, still going very strong :thumbsup:
That's great
Anyone else have sustained track-work experiences for Yellow Jackets???
A few years back I started to get a miss at 4500-5000rpm on acceleration (peak torque).
Pulled out the stock coils and cleaned em, then wrapped em with self amalgamating tape, checked plugs, still missed so old coil had had it.
Bought splitfires from just jap, put em in, no more missfire, no problem at all since and that was like over 4 years ago!
Run up to around 470hp at the treads and no probs.
Yellow jackets look like a good replacement from what you guys have experienced though.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
