I would definently say you need carbs.
Your brain needs glucose.
If you are trying to build muscle/put on size I would think you'd need a reasonably large amount of complex carbs along with lots of protein.
I don't like following diets and it's pretty surprising how much healthy food you can eat without getting fat when you lift 4+ times a week.
Your body doesn't need carbohydrates to function, but it does need them to function efficiently.
If you have to abstain from carbohydrates in your diet, then you are eating the wrong carbs.
Dare i say it again, but if you eat properly, you will never have to go on a diet.
This... f**k low carb diets
For those that have asked about Albuterex previously:
http://www.tga.gov.au/safety/alerts-medicine-albuterex-xtreme-121221.htm
Looks like it might have been a lot more effectively than previously speculated LOL
no it's not a measurable difference, you can burn up to an extra 60 calories I believe
Actually you are mistaken. There is actually no such thing as negative calorie foods, despite what the health gurus like to say. Generally speaking, about 5 to 15% of our daily caloric intake is wasted on digestion. The highest burning substance is protein at about 20 to 25%. That means that if you eat 100 calories worth of protein, it will take 20 to 25 calories to digest it.
Celery on the other hand has very little nutritional value, and contains cellulose (which the body can't digest), so it takes very little energy to digest (and chewing it takes bugger all energy either, something like 10 to 15 calories per hour). So if you eat a stalk of celery (containing about 8 calories), you will only burn off 1 or 2 of those calories in the process,
http://www.tga.gov.a...reme-121221.htm
Chestbrah won't be happy.
Dam and I was going to give alburtrex a go........
In the states at the moment, haven't hit the gym for 2-3 weeks. Feeling the effects already some good and others not so much. Shit food is doing my head in as well. The yanks need some lessons on how to cook eggs and bacon
yeah I want to get to the gym as well. Far too much good food and wine with little exercise.
But..... bloody well shagged my left knee joint after it collapsed on me, twice. Hopefully just a cruciate strain or small tear, but cant tell at the moment.
Might head in anyway and try some upperbody stuff. Just dont want to stand up much atm.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
    • did someone fill up the tank with rain water? lol
    • Slapped a HDi front mount on the M35 last week.
