Deads are coming along again after a deload, only warm up weight for some but on my last 2 sets today I managed 5 x 150kg then 3 X 160kg, I should have only gone to 155kg and will drop my last set to 155kg next time.
I did manage a good 270kg from the top of the knee to lock out on my last set of 5 x 1 of them though, started at 250kg and went up by 5, I did make some noise though.
I am going to rotate between 3 x 8 deficit and 5 x 1 knee height to try and keep it slowly going up.
Sorted out all those injuries that prevent you from progressing yet Dan?
Is this supposed to be a thinly veiled jab somehow? Despite me having already said I wouldn't be lecturing anyone based on having injured myself with poor form/mechanics? If so, lol
100kg x 7 on bench, I think that's a pb for me!
Nice job dude. I'm slowly bringing up that 3rd incline set, started out at 54kg and the bar was very hard to control, now got about 75 on it and managing 10 reps (just) after doing 10 then 8 at of flat something just over 100, think it's like 102.5 or so.
Thinking I might drop the second flat bench set and swap in another incline set as I don't want too big man titties (I have cut eating also to assist until I can do some decent cardio again).
Edited by ActionDan
Mine are big enough now. I don't want them to be any bigger to make it easier when my metabolism slows more and I find it harder to change weight as easy.
My thinking is that as I get older I'll slowly lean off a bit over time to avoid sag if possible lol
Hahah, that's my thinking too, but I more so mean I'll step down in weights and move more into cardio as I get older. For that leaner less bulky look and hopefully that will help keep me tight like a tiger.
What's a better game plan then, legit question.
My theory is if the muscle is a little smaller through lighter weights higher reps and my body fat is lower through cardio and diet I should be OK.
I know muscle itself doesn't sag but the connective tissues do. Less weight on those would help.
Less fat is always going to help.
All old people sag - fact. No training will avoid that. Even skinny low fat triathlete oldies sag. You either get lucky or you don't.
Look at Stallone...as roided up as he is, he's in top nick for a man in his 60s...very defined...but you can see the age; you can see the sag. Nothing can be done. Deal wit it.
Keep the fat off and that's the best you can do.
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
