Did my 1RMs tonight - 230kg squat, 200kg deadlift, 120kg bench, 70kg press. Stoked about it - I hit all the goals I was after, and squatted more than I thought I could. 8 or so months of PTC beginner routine and eating LOTS of protein.
Now for my 5/3/1 to begin!
Paradoxically the only thing to cure my calf doms was squatting.
Edited by bozodos
I always go below paralell Birds, I try not to have hamstring touch calf though. Still at 120kg or so unfortunately - diet started to get a bit out of hand again lately. Would have liked to got 240kg squat for double bodyweight, but I didn't want to fail it.
Can't really remember my starting numbers, they were pretty damn low though - when I started the PTC routine I was benching around 40kg, squatting 100 or so, and deadlifting 80. I had to do dips with ~90kg assistance, which I can now do bodyweight.
I've started doing stair / hill runs and sprints to get some conditioning in too.
Sensational man, really happy for you, so jealous of the Squat and DL =D
Happy because you've worked hard for it and happy because your attitude has been excellent since the beginning, no bullshit, no ego, just getting in there and getting it done.
*BroHug*
  • Like 1
Good work Boz. Only real powerlifters squat more than they deadlift!
Don't need to worry about knee wraps but a belt for squats is really handy, especially once it gets heavy. Just helps you keep tight and makes the whole thing a nicer movement.
It doesn't really protect your back and only maybe gets you a handful of kilos but it's definitely worth having.
Thanks Nick. I'll look into a belt - my Chuck Taylors are here so at least I'll have some reasonable footwear. I've had a strong squat and legs since I started, lucky I guess.
Been agonising over 5/3/1 assistance templates, I decided on Simplest Strength due to it having a squat and deadlift variant more than once a week, and not eating enough to give BBB a hard go
5 sets of 5, there's a heap of different programs, Markos always used to reccomend it more for lifters beyond the beginner stage, and I'd agree with that.
Common examples of programs are: Stronglifts, LP Greyskull, Madcow, Bill Starr's 5x5.
Cheers boz, I had a quick look online but thought id ask my fellow gym sauers. I had a chat with a 50 year old at the gym today. This bloke is bigger than most blokes at the gym. He said for me to shake up the routine ( 5x5, pyramid etc ) he swears by the pyramid program.
http://blackironbeast.com has a good calculator for 5/3/1.
I have started the boring but big program 4 day, very similar to the program I was doing but all the % and sets are done for you.
I will roll with this for the full cycle (about 9 months worth) from now and see how it goes, 2 days in so far.
I like it as it seems its a "get strong for dummies" type of thing, which suits me down to a tee.
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
