  • Replies 312
Posted Images
the supras are an awesome car. plenty of grunt and huge potential. i was looking to buy one before the skyline. i only chose the 33 over the supra due to the supra being a bit too bulky for me. oh.. and i didnt like the interior. too spaceship like.
Tell your friend to get a targa top Supra, hes gonna have trouble fitting his head in it otherwise...
Supras aren't a bad thing IMO. NA ones are ghey, but TT manual ones = :)
I think they are too heavy, the styling looks good from some angles but completely obese from others and the interior is questionable - but at the end of the day, that engine...
2jz ftmfw
Yeah and he smashed it hahahaha
do turbo model supra's only come in TT?
im sure Nick(hulk's son) changed to a single turbo..confirmation....?
yeh i watch the show a fair bit.
Last night Hulk learned how to drift aswell to show Nick and Hulk ripped some nice circle work in a Practice 350z. not bad,not bad at all.. and yeh Nick was driving a Dodge Viper(drift car) i think,was all colourfull,
im only used to seeing Vipers in blue.
Nah its a HUGE trend with supras to flick the stock twin setup and put a T51R or T04Z on there
as much as it pains me to say this but a 2JZ (with turbo and plenum swapped positions) in a GTR would probaby the ultimate thing.
:) You're right, but something inside just tells me "but there's more to it than that..."
It's be unfair if the RB was stronger than 2JZ...the only fans Toyota would have would be mums dropping the kids off every morning ;)
Supra = cheap drag car
GTR = out-of-the-box circuit monster
was going to buy one till i sat in it... how small is the interior!! how crappy does it look... the back seat is pointless.. and most come in auto!!
exactly what I wanted to say...!!! I used to love supras until the day came when I actually sat in one.Me being 6ft tall i had the drivers seat pressed against the joke of a backseat.And even then I just couldnt believe how such a big car can be so small inside..Honda Integras have more interior room FFS.
Those who complain about the weight of the supra are totally misinformed, the supra weighs 1510kg go and check the weight of an r33 or 34 gtr and you will get a surprise.
The 2JZ shits all over the RB26 for strength, durability and potential. The six throttlebody manifold on the RB26 is a beautiful thing but is a negligable advantage in the overall scheme of things. Lets face it, that extra .4 of a litre more than makes up for those throttle bodies.
The 6 speed Getrag is near invinceable, there are supras popping the front wheels off the ground run after run will over 1000rwhp and still standing upto the power, torque and abuse on an unopened gearbox. It is possible to break one but very rare all the same unlike anything nissan.
Yes the stock turbos are a pain in the ass but there are many options if you are a switched on supra owner. There are many supras running high flowed steel wheeled twins making 320+rwkw. My cousins does 327rwkw on US spec factory turbos, there is now also a manufacturer who replaces the standard cartridge with a GT28R cartridge not to mention the number of single turbo kits available.
Traction issues, what traction issues??? You can fit 325's on the rear just by rolloing the lip and getting the right offset.
By the way, its just not a fair comparison. The supra so far above the gtst(which was the original caomparison remember?) its not fair to compare.
Supra Vs Gtr, well they are chalk and cheese and both have their strong and weak points.
I am not biased, i am experienced and have owned the cars in question plus many others and if i wanted many miles of trouble free enjoyable driving(sometimes a little spirited) then i would pick the supra. Skylines, including gtr's(the r34 less so) are just too expensive to make strong, reliable and powerful.
Edited by fieds83
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
