black wingless r34 with a big 'got rice?' sticker on the back making all sort of automatic noise up the Burwood Highway
Yep that would be me.. lol got new exhaust system.. :D got rid of sticker though. cops dont like it haha
Spotted quite a few Skylines today/tonight..
Spotted a White Series 1 GTS-T? R33 - plates TST-XXX sitting in the Westfield - Fountain Gate Shopping Centre car park.
Spotted a Blue GTR R34 - plates UQD-XXX at the Calder Freeway / Tullamarine Freeway interchange.
Spotted 2 Skylines, one GTR R32 and one R33 at Kings.
Yep that would be me.. lol got new exhaust system.. :) got rid of sticker though. cops dont like it haha
lol, I'm at the Springvale/Burwood intersection and hear this racket...though it was a Harley or something....
then this comes ripping past me (I was in the black r33) made me lol
Thats my old r34. The guy who bought it lives in Narre Warren
Ahh yeah that makes sense thought it looked exactly like your car.. See him around sumtimes, seems to go pretty well he gunned it around the petrol station last week when he saw a few of my mates checking out the car
LoL really..hrmm he must have changed the spark plugs then LoL it went shit when i had it :thumbsup:
