spotted a black 32 in front of parkmore, near the maccas. custom plates starting with GO****
thats was GOD2LA he on the forum but not that much when u comeing by shop :cheers: spoted ford mustang couple of days ago on my way to get complaince finally he said to my friend beside me V8's are better :cheers: bah lucky car is stock lol
ok spotted a black r32 on stud rd near stud park shopping centre i was the first white 33 that passed u. and then saw a silver 33 goin the other way moments later.
what time?
I was going up stud road (towards knox) at around 5:15pm..
I have no spoiler and uras ns-01 rims?
was it me?
what time?
was it me?
i dunno whats ur plate start wif?? if it was u did u turn into stud park? had p plates up.
nah i didnt turn into studpark, but had P-Plates up.
rego plates are UIE710
cant remember the plates, all i can remember was that the 32 turned off wellington rd on to stud rd and then turned right at studpark where red rooster is.
spotted 2 white R33 skylines in Shepparton on Saturday nyt.. One had a black hood with bodykit, the other pretty stock and just rims.. both plates seemed similar.. Nutr33 or something.. btw i dont live in shepparton and im pretty sure i had spotted these cars in melb as well.. peace
they were probably up there for DECA
spotted a few sau members today. a silver r33 going up burwood hwy just about to approach mount dandy. custom plates X something didnt see.
spotted [R33ER] just off mountain hwy parked outside kfc
spotted [CAJFLY] on burwood hwy aswell =P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
