spotted a black 32 in front of parkmore, near the maccas. custom plates starting with GO****
thats was GOD2LA he on the forum but not that much when u comeing by shop :cheers: spoted ford mustang couple of days ago on my way to get complaince finally he said to my friend beside me V8's are better :cheers: bah lucky car is stock lol
ok spotted a black r32 on stud rd near stud park shopping centre i was the first white 33 that passed u. and then saw a silver 33 goin the other way moments later.
what time?
I was going up stud road (towards knox) at around 5:15pm..
I have no spoiler and uras ns-01 rims?
was it me?
what time?
was it me?
i dunno whats ur plate start wif?? if it was u did u turn into stud park? had p plates up.
nah i didnt turn into studpark, but had P-Plates up.
rego plates are UIE710
cant remember the plates, all i can remember was that the 32 turned off wellington rd on to stud rd and then turned right at studpark where red rooster is.
spotted 2 white R33 skylines in Shepparton on Saturday nyt.. One had a black hood with bodykit, the other pretty stock and just rims.. both plates seemed similar.. Nutr33 or something.. btw i dont live in shepparton and im pretty sure i had spotted these cars in melb as well.. peace
they were probably up there for DECA
spotted a few sau members today. a silver r33 going up burwood hwy just about to approach mount dandy. custom plates X something didnt see.
spotted [R33ER] just off mountain hwy parked outside kfc
spotted [CAJFLY] on burwood hwy aswell =P
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
