spotted a black 32 in front of parkmore, near the maccas. custom plates starting with GO****
thats was GOD2LA he on the forum but not that much when u comeing by shop :cheers: spoted ford mustang couple of days ago on my way to get complaince finally he said to my friend beside me V8's are better :cheers: bah lucky car is stock lol
ok spotted a black r32 on stud rd near stud park shopping centre i was the first white 33 that passed u. and then saw a silver 33 goin the other way moments later.
what time?
I was going up stud road (towards knox) at around 5:15pm..
I have no spoiler and uras ns-01 rims?
was it me?
what time?
was it me?
i dunno whats ur plate start wif?? if it was u did u turn into stud park? had p plates up.
nah i didnt turn into studpark, but had P-Plates up.
rego plates are UIE710
cant remember the plates, all i can remember was that the 32 turned off wellington rd on to stud rd and then turned right at studpark where red rooster is.
spotted 2 white R33 skylines in Shepparton on Saturday nyt.. One had a black hood with bodykit, the other pretty stock and just rims.. both plates seemed similar.. Nutr33 or something.. btw i dont live in shepparton and im pretty sure i had spotted these cars in melb as well.. peace
they were probably up there for DECA
spotted a few sau members today. a silver r33 going up burwood hwy just about to approach mount dandy. custom plates X something didnt see.
spotted [R33ER] just off mountain hwy parked outside kfc
spotted [CAJFLY] on burwood hwy aswell =P
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
