LOL!
Don't ya just hate those car all riced up and junk. :D
If I see one I just sit and think WTF?
oh yea to the point i want to carry a screw driver around and take them off their cars if it aint a GTR why put a GTR badge its like driving a RX and puting a WRX badge on and the whole bonnet and everything who the fu*k is sad enough to do that lol
Amen brother!
LOL!
yeah thats a guy i knows strunt driving school those echo's have welded diffs hence they drive over a ramp making the car drive on just the front right and rear right wheels in a stright line its funny as to watch and good fun too
Spotted a 4wd towing an echo with the rego plates 2wheelin. Had stuntdriving sticker on the side of the ehco.
Was on princes hwy turning right onto blackburn road :/
Yeah that would be Kev (kevwrx)
I would guess he was having a wheel stud fixed.. But just a guess.
No way.. On 2 wheels ya say.. That guys mad...
As for the Echo's only 1 has the welded diff
The others are stock but in saying that. 1 has a hydraulic hand brake..
black r34 gtr today on corner of manningham/bulleen roads.. plates WED###
looked like some middle aged guy, giving it a bit of a squirt...
Gotta love this thread lol
Thats my car, I was in the passenger seat, the guy driving was 23yo, he didnt go over the speed limit ONCE on the entire 3 hour drive till he was 10 minutes from Frankston. Still, lets not ruin a good story with the truth. Maybe black 34's look fast standing still lol
QUOTE(iseekool @ 30 Sep 2008, 09:45 PM) post_snapback.gif - Saw a R34 GTR corner of high st and mahoneys rd - it was either blue or black from memory
That was me! I think I remember seeing you :P
You got a really nice clean car there mate :D
If you saw a white r34 4 door that night that would have been me - I flashed my lights too.
Just spotted a silver R34 with SAU stickers driving from Power St onto Whiteman St past Crown...
5 seconds later spotted a black R33 with SAU stickers & personalised plates, something like PAS??? turning onto Queensbridge St from Power St...
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
