Spotted Thread
paulr33
Every morning (when im on mornings or evening shift) i see a white R32 GTR either on heatherton road or parking on cockring road.
I keep seeing this White R32 GT-R in Moorabbin area "NSMO32" or "NZMO32"
Same one that i keep seeing... dont see any SAU stickers on it though.
Cockring Road = Cochranes Road Moorabbin
massive thanks to the guy in the new gtr (red) that gave it a squirt for me up mt.dandy road this morning wish the lights didn't go green would have loved a chat with you.
Spotted him as well if his plates were SPECV. I was on my bike though.
needa spot some more skylines in geelong. go out for a cruise Friday night :)
i'll be going through geelong tonight around 12 or tomorrow morning, but now you got that bypass the avoids the whole RED LIGHT CAMERA and 70kph speedzones, i'll take the bypass at 100kph :stupid: keep an eye out lol
i'll be going through geelong tonight around 12 or tomorrow morning, but now you got that bypass the avoids the whole RED LIGHT CAMERA and 70kph speedzones, i'll take the bypass at 100kph :P keep an eye out lol
that bypass is ideal. leads me straight to uni :/
Black r33 gts-t coupe with Advan wheels. Around 1.30am. plate number "jnrzan". Cruised from Fitzroy to Regent.
Was that you next to me down st georges road in the white 4 door 34?
lots of lines on princess hwy last night
yeah a saw a r33 pulled up
and r32 pulled up dude was on the phone so maybe ringing for a taxi ??
and a white r34 gtr Vspec :banana: getting egged on my holdens and WRX's, i was just happy to sit back and watch and listen to it.
That was me - you got a really clean car there :)
I saw that "hoon spec" statesman tailing you pretty bad at Regent - he pretty much cut me off ;)
The stove top lights sure set people off :banana:
Spotted a grey 32 gts-t on Spencer St today, about lunch time. Big fluttery BOV, and the No. plate was offset to the drivers side.
Also a white 33 gts with gold wheels turning off bridge Rd(?) on to lennox rd near Epworth Hospital.
That was me - you got a really clean car there :P
I saw that "hoon spec" statesman tailing you pretty bad at Regent - he pretty much cut me off :P
The stove top lights sure set people off :down:
Yeah they sure do he was sitting on my arse for a while
BTW wat headlights do you have in your car they look really white.... can you see well with them well at night?
    • Agreed with the rest. Also at least based on my own research, there are no readily available stock or close-to-stock RB20Neo maps that you could download and use as a base were you to buy a complete standalone ECU, and the regular 20DET maps don't really work well so you'd need to take it to a tuner if you have no experience. I installed an AEM V2 on my 20Neo+T and had lots of headaches until I got it to run and idle properly but I've yet to remap it fully. You have to start building up your timing and fuel maps entirely from the ground up; even the ones for a 25 didn't work at all.
    • Got some decent progress after work yesterday and also today. Got the ECU all wired and passenger side interior all back together. Kept the wiring up nice and high to avoid people standing on it. Got the surge tank relays rewired and tidied up the pump wiring and cut a hole to bring the cables through.  I found a spare USB cable I had lying around so I decided to cut it up and see if I could use it for my CAN 1 bus. Turned out one of the pins I needed was to the shield of the cable so i cut it up and desoldered it and resoldered to the correct pins.  Had the issue with the powersteering hose hitting the A/C compressor and fan shroud. I pulled the bracket off and modified it to remove the front mounting point which now clears it all. Will keep an eye on it to see if theres any signs of fouling once it's up and running.
    • That's some good input mate. Nice.
    • So today I went well outside my comfort zone (again) to replace my valve cover gasket.  I have had a big leak over the exhaust leading to a lot of smoke and smell every time I drove it. The leak was in the rear driver's corner.  The job wasn't hard as such, just a bit finicky and time consuming.  The old gasket was rock hard and broken right where the leak was.  The leaky corner had so much sitting oil in it.  The good news to my amateur eyes was no buildup or sludge under the cover. It all looked fairly nice in there.   I haven't started it yet. I ran out of light and body when putting the coils and injector loom back in. Probs only 30min left for the morning.  I was so nervous putting the cover back on, I must have lifted it 5 times to make sure the gasket was still seated properly. God it's going to be nice to be leak free and not make other traffic light queuers think my car is about to explode.
    • Gave the Mazda it's first wash, it will need some clay, a light compound, and polish polish to remove a few swirl marks, but that will be a job for when I have a full day to get my DA polisher action on
