Spotted a silver R34 sedan with SAU stickers on Boundary Road tonight turning onto Cheltenham Road with plates "GTTR-34" or something?
Although I was on the opposite side of the road, it sounded awesome!
saw some guy in an sau hoodie walk past my work today (tattoo shop in bacchus marsh) at about 2:30ish.
i'm guessing its the same guy who drives the sweet track looking white 31 with sau stickers which i saw parked in the main st right across from the police station...
im from the marsh btw esther... never even looked at the tatto shop and i drink at the courthouse at least once a week, lol :ermm:
Edited by thommo
Was it parked at Coles?
Or was it parked on Sir John Monash Dr?
If it's at Coles, I saw it too :ermm:
If it's at Sir John Monash Dr, then it's mine :bunny:
is yours an automatic ? with number plates that starts with UAE or something ? suppose your from United Arab Emirates yea ? think i saw yours parked in monash caulfield
it's not the same guy, that "sweet track looking white 31" is mine :bunny: ..I'm Esthers bf, was picking her up from work.
Jesse bet me to it, but yes, the 31's his. Pop into my work sometime, i'm there pretty much whenever w're open. Just let me know you're the guy from the marsh :bunny:
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
