spotted mint white 33gtr with RPFs next to flinders street heading to russel st about 1 today.
clean as :thumbsup:
That would have been me. Why didn't i see you? Were you in the Skyline, I normally give a wave when I see a fellow enthusiast in a great car.
Car's been sitting in the garage and it was so nice just to take her out and potter around.
That was me :) !!!!!!!
What were you driving??
You might have seen mine parked at the council parking :)
I was in the missus' cruze(POS lol)
Stag was in the garage not wanting to be driven for that weekend!
I liked the wheels man. polished look always comes up the best!
do you work at the council or??
spotted a silver/grey s2 r33 gtst on somerton rd bout 4:45pm, black s1 r33 gtst with a lip spoiler on somerton rd near holden round 5pm, and a black r34 gtt with a blonde drivn :thumbsup: was turning into donald cameron drv bout 5:10pm didnt catch any plates tho
nah man was in my is250
car looked awesome man really clean top effort :thumbsup:
Tuesday night, I was U-turning on blackburn rd (just outside blacky maccas) and a red (i think xD) r33 turning left in the road I was semi-using to complete u-turn haha. I guess this would have been around...1am?
Passed by a silver R33 (Well I think it was silver...wow my short term memory is failing LOL) on my left on springvale rd, passing glen waverly a bit past 7pm tonight. Was in the black r34 in the middle lane. Well dunno if you even saw, but yes :P.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
