Black 35 in Docklands today.
And off topic, black VE SS ute with front driver's side completely smashed in at corner of La Trobe and Spencer being picked up by a tow truck. Played chicken with an old white Corolla and lost by the looks of it.
Spotted a gorgeous black R35 GT-R with personalised/custom plates, big aftermarket wheels and aftermarket exhausts(?) cruising along Clarendon St tonight. Sounded absolutely hot, even on low revs :):)
Also an assortment of other Skylines as well spotted in the same area throughout the night. 2x black ECR33's as well as a silver ECR33 that was particularly loud.
Silver CPV35 parked under bridge near westgate city-inbound with hazards on around 11pm? Hope all was ok...
Edited by GT32
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
