Once again saw that mint blue R34 GTR. Nismo (?) FMIC, high wing stands, white rims. Looked immac. Saw you driving down Burwood rd Hawthorn. Your on the homepage of JDMST, EOMM pics. Schmick!
Birds going down Burwood Hwy, I was at Mountain Hwy intersection.
Maroon Stagea with SAU Stickers on Burwood Hwy about 15 mins ago
Must have been on the way to the gym! :wave:
Still have not washed your car.... stalked you through the mean streets of back Eltham last night. Dropped a fast one past your car at about 6:30... you may have heard it
I have, it just got dirty again. White car + "high flow" cat = bad
Didn't see you, should have beeped... or gassed it more
Yellow 34 on eastern heading Ringwood bound.
Clean looking white 2 door 34 on eastern, stuck in the parked lane for Chandler.
Eastern is horrible this mourning terrible
White 34 would have been me!
Yeah as soon as I see that it's banking up to just past the chandler exit I just get off at chandler & go through the boulevard to work - saves so much time when the traffic is sh*t & you get a nice pre-work twistie drive :P
beautiful Silver R34 with a red badge on the front coming out of Bunnings Clayton today. Must have been polished recently; looked like a new car! There's also a clean grey R34 i see all the time at domain paper around my area too. Wonder if they are ever on here.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
