Clean red SVD R31 with white wheels and personalised plates following me, this morning along Warrigul Rd.
Saw a white R34 coupe (not sure if it was a GTt or GTR from afar) along Dalton Rd Thomastown around 9am.
Spotted...
  1. white r32 gtr - dynon rd
  2. gray r35 gtr - also on dynon & followed it to droop st
  3. whole passels of skylines @ chasers
  4. white r33 - droop st/geelong rd
  5. burnt orange 350z - also on droop st
  6. forest green s14 - ballarat rd
  7. another forest green s14 - followed from mt derrimut rd into brimbank gardens
:down: was bored going home today so was playing spot the jap imports
Wine red R33 boosted it past me along St Georges rd.
I caught up at the red light - he kept looking forward....
Big NISMO sticker across the rear windscreen
I feel no love.
Why show off and not look at me? You obviously proved you can reach a red light faster than me.
on the other hand i cruised with a sexspec little fwd thing. so much kit chrome and candy green that i couldn't tell what it was, but it was turbo, and fast. took it very easy despite four or five commodores trying to race the both of us all the way down stud rd from knox. gave it a little hit to 80 at cheltenham rd from chandler rd lights, gave eachother a wave, and he turned off, i went home. guys in r33's are massive dicks in comparison
I feel no love.
See my diagram up top for an explanation!
I think I've had one R33 acknowledge me, ever...and that was the night I picked up my car :P
What pisses me off though, is that you know they know you're there...it must take some control to just keep looking forward like that and pretending you don't notice.
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
    • okay, so I figured this out, removed needles and reinstalled after swapping the gauge face on my triple gauge for my ER34, all work and look good. I tried to do the same for the main cluster, but the main cluster gauge faces are dished, the replacement gauge face are flat, so due to the dish in the org face ,mounting backing plate (clear) and depth of the needle, the flat gauge face will not work. I notice that R34 gtr gauges are flat, appears to be different clear backing plate that aren't dished. are these available, or what have others done to install flat gauge faces?
    • Cheers mate. Seems some people get lucky others don't. It looks like the motor was detonating (to be expected if it was overboosting I suppose) as the pistons had a lot of detonation damage, and the bearings were stuffed. The bores were very scoured too, not sure if that's from the pistons or bits of ceramic turbo. By the by now. Have been trying to avoid the rabbit hole too much on the rebuild, and there's been a few hurdles along the way, but with any luck I'll have the car back soon™. Might even pop up a thread then.
