Since the hi-jacking of my N1 block thread (dont get me wrong - if N1 oil pumps are a hot topic, then I am glag I could initiate some dialog..)
I thought I would try a different tact for my next topic...
if one was building a RB26 for response - what woild you do... feel free to explore (but not limit youself to) Turbos, Compression ratio, Cams and Cam Timing. I would like to keep this topic about RB26 if possible - 2.8 etc have there obvious benifits... but lets just say we want to stick with 2.6 for now...
Want to make as much power / torque down low as possible.
So building a good responsive RB26 for a mostley street car...you would.......
(your opinion goes here)
Looking forward to the banter again. Love this forum :)
Edited by Antimatter
https://www.sau.com.au/forums/topic/219857-building-an-rb26-for-response/
Looking forward to the banter again. Love this forum :starwars:
im running n1 turbos and they are extremely responsive for the street, i couldnt believe how progressive the power delivery is......they dont seem to run out of puff as well, and will hold boost nicely all the way to 7000rpm:)
I notice your other thread made mention of 400rwkw?
If going for response, it's the GT-SS/ -7's as a the combo of choice. But you wont see anything like 400rwkw. 320rwkw is about it.
The hold till 8000rpm when setup correctly.
With injectors, AFM/PFC & nice rebuild and a tidy up of the head and so on… its basically like having the RB26 with factory turbos, but it'll make you the extra 60-80rwkw with 20+ psi making it feel very meaty. Provided your tuner knows how to play with cam gears and so on.
Just whatever dumps and you could increase the comp slightly being fuel in todays world is a bit better here in AUS compared to 10-15years ago.
Hey Ash
I did mention 400kw.... and I would love this + response, but I also understand that without going to 2.8 or 3.0 It is going to be a compromise. Just curious to see peoples experience with response and there own setups....
I have seen some really good compromises with Apexi (AX Series) Turbos seeing around the 370kw mark - however these are sadly discontinued.
on the other hand... how responsive can -5's be "made to be" with the right cam timing and compression?
Steve
Rb26 eh?
Response only, no power goal.
Rip off the turbos, increase the compression ratio to 10.8:1 with some RB25DE pistons, lighten the flywheel, fit the 4.35 diffs out of an R32 GTS4 and fit some tube extractors.
Throttle response with the six throttle body induction should be pretty instantaneous.
Well you did ask...........
I spose I did :D
Now can I have that and 350kw?
:w00t:
Rb26 eh?
Hey Ash
Steve
-5's aren't too bad.
Snowmans car is one of the signature cars for it, its sooo much nicer than it was a few years ago and thats just R&D really (Racepace)
And considering your Melb - its probably the place i'd be going to bounce some ideas around and go for a buzz in a few of the Vic guys cars with the -7 and -5 and see for yourself which set-up suits best.
Having owned GTR's that are stock (211rwkw), mild ( 280rwkw), pretty fast (370rwkw) and the best (460rwkw), I dont think I would ever opt for anything other than 460rwkw again. I am currently driving a GTR with 225rwkw and hating it, its for sale.
Again, this is just an opinion, and all of those cars were 100% street driven, everyday, never been on a track with a GTR. In my opinion, the difference between lag and response is gear selection.
For the sake of your thread, the 370rwkw was an HKS 2530 set up.
Have heared 2530's and -5's are pretty similar.... or is that GT-RS and -5's?
Been told that -5's are in pretty short supply at the moment too....
I guess the turbos will be the big factor - but if I were building an engine.. "slightly" higher comp.... clean up the ports... and I am on the right track?
I understand a good tune (both ECU and cam timing) goes a long way :w00t:
I understand a good tune (both ECU and cam timing) goes a long way >_<
For me i would..
Head:
Port and polish
260' Cams with good lift
Adjustable cam gears (and dialled in properly)
Bottom End:
9.0:1 Compression Forged Pistons
Forged Rods
Treated crank
Turbos:
HKS 2530 or Garret 2860 -5's
With 1.6-1.9 Bar boost I would expect 400kw atw easily. Im running 2530's with Tomei 260s making 360kw atw on 1.3bar, stock bottom end and no head work. I get full boost around 3,800rpm.
Edited by Blue_GTR
contrary to popular belief, a single can give you the results you're looking for.
Maybe
Fact of the matter is the thread starter is in Vic. Big singles are a no-no down here these days
Low mounts all the way due to the EPA/Police etc
SAU Vics catchcry:
"go see Ben"
(and fair enough too)
:P
... that is a very sexy graph, whats it like to drive?
Here's my latest dyno graph. Racepace -5's set-up.
If this is what you want then go see Ben. If you want / expect even better results on an RB26 then good luck with that.
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
