Since the hi-jacking of my N1 block thread (dont get me wrong - if N1 oil pumps are a hot topic, then I am glag I could initiate some dialog..)
I thought I would try a different tact for my next topic...
if one was building a RB26 for response - what woild you do... feel free to explore (but not limit youself to) Turbos, Compression ratio, Cams and Cam Timing. I would like to keep this topic about RB26 if possible - 2.8 etc have there obvious benifits... but lets just say we want to stick with 2.6 for now...
Want to make as much power / torque down low as possible.
So building a good responsive RB26 for a mostley street car...you would.......
(your opinion goes here)
Looking forward to the banter again. Love this forum :)
Edited by Antimatter
https://www.sau.com.au/forums/topic/219857-building-an-rb26-for-response/
Looking forward to the banter again. Love this forum :starwars:
im running n1 turbos and they are extremely responsive for the street, i couldnt believe how progressive the power delivery is......they dont seem to run out of puff as well, and will hold boost nicely all the way to 7000rpm:)
I notice your other thread made mention of 400rwkw?
If going for response, it's the GT-SS/ -7's as a the combo of choice. But you wont see anything like 400rwkw. 320rwkw is about it.
The hold till 8000rpm when setup correctly.
With injectors, AFM/PFC & nice rebuild and a tidy up of the head and so on… its basically like having the RB26 with factory turbos, but it'll make you the extra 60-80rwkw with 20+ psi making it feel very meaty. Provided your tuner knows how to play with cam gears and so on.
Just whatever dumps and you could increase the comp slightly being fuel in todays world is a bit better here in AUS compared to 10-15years ago.
Hey Ash
I did mention 400kw.... and I would love this + response, but I also understand that without going to 2.8 or 3.0 It is going to be a compromise. Just curious to see peoples experience with response and there own setups....
I have seen some really good compromises with Apexi (AX Series) Turbos seeing around the 370kw mark - however these are sadly discontinued.
on the other hand... how responsive can -5's be "made to be" with the right cam timing and compression?
Steve
Rb26 eh?
Response only, no power goal.
Rip off the turbos, increase the compression ratio to 10.8:1 with some RB25DE pistons, lighten the flywheel, fit the 4.35 diffs out of an R32 GTS4 and fit some tube extractors.
Throttle response with the six throttle body induction should be pretty instantaneous.
Well you did ask...........
I spose I did :D
Now can I have that and 350kw?
:w00t:
Rb26 eh?
Hey Ash
Steve
-5's aren't too bad.
Snowmans car is one of the signature cars for it, its sooo much nicer than it was a few years ago and thats just R&D really (Racepace)
And considering your Melb - its probably the place i'd be going to bounce some ideas around and go for a buzz in a few of the Vic guys cars with the -7 and -5 and see for yourself which set-up suits best.
Having owned GTR's that are stock (211rwkw), mild ( 280rwkw), pretty fast (370rwkw) and the best (460rwkw), I dont think I would ever opt for anything other than 460rwkw again. I am currently driving a GTR with 225rwkw and hating it, its for sale.
Again, this is just an opinion, and all of those cars were 100% street driven, everyday, never been on a track with a GTR. In my opinion, the difference between lag and response is gear selection.
For the sake of your thread, the 370rwkw was an HKS 2530 set up.
Have heared 2530's and -5's are pretty similar.... or is that GT-RS and -5's?
Been told that -5's are in pretty short supply at the moment too....
I guess the turbos will be the big factor - but if I were building an engine.. "slightly" higher comp.... clean up the ports... and I am on the right track?
I understand a good tune (both ECU and cam timing) goes a long way :w00t:
I understand a good tune (both ECU and cam timing) goes a long way >_<
For me i would..
Head:
Port and polish
260' Cams with good lift
Adjustable cam gears (and dialled in properly)
Bottom End:
9.0:1 Compression Forged Pistons
Forged Rods
Treated crank
Turbos:
HKS 2530 or Garret 2860 -5's
With 1.6-1.9 Bar boost I would expect 400kw atw easily. Im running 2530's with Tomei 260s making 360kw atw on 1.3bar, stock bottom end and no head work. I get full boost around 3,800rpm.
Edited by Blue_GTR
contrary to popular belief, a single can give you the results you're looking for.
Maybe
Fact of the matter is the thread starter is in Vic. Big singles are a no-no down here these days
Low mounts all the way due to the EPA/Police etc
SAU Vics catchcry:
"go see Ben"
(and fair enough too)
:P
... that is a very sexy graph, whats it like to drive?
Here's my latest dyno graph. Racepace -5's set-up.
If this is what you want then go see Ben. If you want / expect even better results on an RB26 then good luck with that.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
