The Goods On Oils
PHaT MR30
It's new and should be around for a lot longer than Sougi was, depending on how well the oil sells. I'm anxious to try it in my line but waiting for service interval (not wasting my precious S6000 lol).
If anyone wants to give Syn-X 6000 a shot and can't get it from their local distributor/Autobarn, I can post by the box (4 bottles), which should be pretty cheap. Will start selling it on eBay anyway so keep an eye out on there. Mechanical workshops rave to me about using Syn-X 3000 (10w40) in all their customer cars, so if you want a good semi synth on a budget, you can always chuck that in.
i should try the syn-x 3000
:D
Will throw it in the Skyline over the next couple weeks. Wish the 5w was a 10w, what with summer and everything, but should still be fine (have read that 5w and 10w are negligible in difference and companies often market one as the other etc.). I assume it is a group 4 fully synthetic, given GW said they weren't doing anymore esters. If anyone wants to give it a go I should be able to supply for $55/bottle (plus postage or you can pick up) until further notice, which is still good value for a group 4 synthetic and cheaper than what Sougi 6000 used to cost. It's also an SN/CF, which is the latest specification in the oil industry.
55$ is a bit rich..
Birds can u tell me why this^^^ is any better than this which is only 40$ a bottle at any auto store??
http://www.penriteoil.com.au/products/engine-oils/hpr/hpr_10_full_synthetic
55$ is a bit rich..
http://www.penriteoi..._full_synthetic
It is a higher group oil I think. I'm not 100%
End of the day for what you are doing it probably isn't any better, but you will have the peace of mind of using a better oil.
Hi guys,
I just bought a R34 GTT RB25 NEO over the weekend and drove it up from Brisbane to Cairns.. in the storm :S
I want to get the car serviced, it was a 1700km drive & I want to look after this baby as much as i can :)
I live in Cairns, my vehicle is parked under my complex so we dont really get cold starts or anything here.
Can anyone recommend me a good engine oil? There is 126 pages in this thread, I started reading the 1st few pages then realised that was back in 2003.
This is just my daily driver, I do like to go fast ofcourse but I am not a racer & wont be putting it on a track.
Im hoping somone can lend me a hand.
Cheers,
Shaft
How much are you willing to spend on an oil change?
How much is standard? I mean I dont want to overspend on what is required.
I just wanted to get some ideas of what brand & mix to use. I think grade 3 is what im looking for, but the 10w 5w etc just goes over my head =/
Ok just did alot of reading up on this thread, and apologies for asking noob questions.
Sougi sounds pretty good from what I did read, the S 6000 is now off the market and the SYN-X 6000 is the replacement. I called the GW number and found auto 1 to be the local distributor. $49.95 for 5L
Will give this a run :)
My first oil change in my 33 I used Penrite HPR10. Not knowing about these forums, I had asked in Autobarn and that was what was recommended. Short story, but I did not like that oil. The oil pressure gauge stayed up high way longer before it would normalize to it's proper running setting. The car felt a tad sluggish and after awhile I could hear the lifters or something making noises in the engine. HPR10 is a 10w50 oil and on paper shuold be ok in an RB. My experience told it it wasn't. Once I dropped it and put in some Sougi S6000 the car never felt better. Still using the S6000 and I think have 3 bottles left now :).
Not all oil are the same, but different brands can't even get the same weights either. A 10w in Penrite felt like a 20-30w in another brand.
Birds that new Syn-X 6000 looks interesting. Not so happy about it being 5w though. I think it should have been a 10w40 oil as it's still going to be competing with the Royal Purple, Motul 8100 X-max 10w40 and the Chrono 300V. It's not a bad replacement for Sougi S6000 but it's annoying that yet another oil comes in a 5w40 only with no 10w40 option.
Yeah i got the hpr 10 in now..I've noticed my oil pressure stays a little high too, pretty much constantly on the 3/4 mark..only drops when idling..not sure if it feels sluggish cause I have 30kw extra now :P
I reckon it could handle some abuse but def not as nice as the motul it replaced..was half the price though and is SN rated..
Yeah i have the hpr 10 in now, def not as nice as the motul it replaced..oil pressure stays up around 3/4 mark except on idle when it drops to half..
But i reckon it could handle some a use and it was half the price and is SN rated...i can't comment on if it feels sluggish cause I gained 30kw the same time I put it in..sorry Rolls ;)
    • Blitz ER34 at some point hopefully, should be allowed in Gr3 if they do.
    • Stock R33 boost control, with the exhaust, and FMIC done, will boost creep. There is no tuning around it if it is the factory boost solenoid.   If it has an aftermarket electronic boost controller, the settings/mapping can be altered in it.   Oil could be anything as mentioned, however did it ever do it before you did the turbo swap? How much and how often did you drive the car before the swap?   I'm hinging on too much oil supply, or it's not draining properly.   To check, pull the air outlet off the turbo. Is it full of oil? Drop the exhaust at the turbo, does it appears to be oiled/coked? Now pull turbo and check the exhaust manifold, does it appears oiled and coked the same way?   Secondly, the PCV could even be stuffed / not functioning properly and will cause blowing of blue smoke.
    • Almost any ECU would work, from a 30 yr old PowerFC to a new Motec/Autronic. But presumably you want new middle of the road ECU, meaning that you want a Haltech or a Link, most likely. As to which model though? I dunno. I don't keep track of what they have in their current ranges. You don't want a plug in though, because plug ins can start to cause you the same wiring issues that you have to chase up with your stock ECU/loom swaps when an engine transplant is involved. If you use a Haltech (and presumably a Link) you could put the base map for the engine in and drive it around and not even need to "tune" it. It will work just fine. I can't recommend a tuner without a location (and even then I can't recommend many, being as I never use any tuners except myself and my brother-in-law). And not many tuners are happy to remote tune. Maybe they'd be happier doing it for a basically stock setup that just needs to be demonstrated to be working properly. But even then, not being able to be with the car to see what the hell is going on and sort out the inevitable problems that will result from an engine conversion done by an amateur..... unlikely to be enthusiastic about the job. And if you think that just adding 2 wires for the boost sensor is difficult - you don't want to be trying to install and set up an aftermarket ECU. You're going to have to bite down hard on something with either approach.
    • wired everything up and confirmed that the red with white stripe is indeed the fuel pump pin on this harness.
