  • 3 weeks later...
For a street engine, anything over 40w is probably just accelerating wear and tear, the thin oil will flow faster and absorb/transfer heat better leading to less wear and quicker up to temperature... :camping:
5-60 is thick when its cold, compare it to a 5-30, the whole number thing is confusing maybe it should of been rated like 30-5 and 60-5??
Even with the best oil though, you probably get oil being washed off the bore under rich running conditions, so I use Lucas UCL which hopefully sprays lube on the cylinder ( top fuel dragsters use it) and I started adding
Zddp additive just to relieve my OCD thinking... but now i'll have to think of a 4th thing just to make it even cause 3 is bothering me now hahaha :glare:
Edited by AngryRB
Good thing about penrite is that it has always been high in zinc.
Cold viscosity is an issue with thicker oils but really the choice should be based on the level of protection at maximum stress, ie very high temps and high rpm . Speaking of additives, have seen slick50 used in the past and been impressed with the oil analysis that came back, given a lot of these were on chevys, but still a notable difference was seen in the wear particles.
Edited by XGTRX
The numbers on the pack don't mean much.You need to search for the actual viscosity at 40 and 100 degrees and go from there. Its got a name that I've forgotten.
Some would say they are the single most important thing to consider when selecting oil. They specify the range of viscosity, eg a -30 can be 9.3-12.5 and a -40 can be 12.5-16.3 at 100 degC.
I usually look to see what cars it is recommended for, Mobil says for GTR and is used as factory fill in many cars, part of me doubts whether penrite being Australian would have as much R & D as oils made in say Germany and Japan
kind of like comparing an aussie product like a Falcon or a beer with other products from Germany or Japan,
Edited by AngryRB
Mean while, my GT-R always had Penrite oils in it. My R32 got Mobil 1 5W-50, swapped to Penrite and the engine sounded smoother :P.
BTW my car overheated twice (no oil cooler) at a track day, 10W-40 (Penrite Racing 10) did well then (still dropped ~5L out at next oil change, I put 5L in).
You'll be getting very similar protection regardless of brand (if they're proper synthetic).
SAE Viscosity 25W60
Kinematics Viscosity
Visc @ 40oC 270
Visc @ 100oC 23.5
TBN 9.31
Pour Point oC - 27
Flash Point COC oC 210
Does this seem like a good oil
Too thick for an RB with standard bearing tolerances. You'll just be pushing a lot of oil through the filter bypass and relief valves.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
