Timmy and I had plans to be there, but we've decided to take another year off to persue other interests.
We've decided 2013 is our comeback year all going well. Hopefully our car isn't too uncompetetive by then.....
Have my car back to the way it was before the telegraph pole incident on the Cygnet stage @ TWP, currently being prepared to run Wrest point again and dipping the toes into TT by entering rookie for 2012.
Cheers for the input on the rear guys. That is by far the hardest part of the project, so if those in the know feel it is not worthwhile I will reconsider. Cost isnt a major consideration as I have some good engineering mates who will help with the work at the right price and have a complete MX5 at the right price to salvage all parts and to use as a guide. Have already got guys who beef up the MX5 rear end and can make FD diffs work for the guys that are already putting rotors and V8s in MX5's. Main challenge is prepping the shell to accept the subframe, and getting it at the right height to have correct roll centre. The upsaide is once its in with some decent coilovers, you have good amounts of ride height, camber and toe adjustment to fine tune the handling.
Great to hear you are getting back amongst it Scott.
Maybe its time for his to return in 2013??? 2013 - BATTLE FOR THE WANG!!!!!!!!!!!
Edited by Darkside
Wow somebody took a bite out of it! Who knows where that thing has been!
No matter what you're never getting the smell of it out of your house Paris!
My plans after getting the new car was to get back for THC'12 - but I really don't know how accurate those plans are these days LOL
Like Woo - I've got lots of other plans I'd like to do next year.
And I'd still like to look at Pikes one day.
Maybe once I get this car actually running properly I will think about what I will do with it.
So who does one have to pester to get a course car job for one of the rallies (TT12 would be awesome). Now it's with CAMS I can throw my hand up for having a bronze rally officials license which means I can check/set the rally stages and I'm not afraid to sit in the silly seat while doing so.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
