Yep Kel is off in the morning to do it mx5 style again.
And you can redrill those holes for sure....the knurls are only there to stop it turning when the wheelnut is going on, the thread does all the clamping work.
Thanks Mr "unf**kingsubscribed" :) Definitely dumber from reading that thread,.
EDIT: And best of luck to all those having a crack at TWP this weekend. Have a fast, fun safe one.
Just don't use cheap studs. Cheap studs have soft knurles and have a tendency to spin in the hub. And bind on the threads. It's no fun trying to undo a nut off a turning thread.
I'll be interested to see if kell only drinks 2 days worth of drink rather than the 5 days worth she drinks after TT
Edited by DJRIFT
Fellas,
little tech question. I have a minor issue where the front studs on the mazda are 12x1.5 thread and the studs on the floater rear are .5" unf. Ideally I would like to run the same thread/wheelnut front and rear. I guess the preference would be to go for the larger .5" stud all round. Have looked around and there aren't any studs I can find with the right sized knurl to be a press in option for the front hub in the .5" thread. Am guessing its not possible to get the knurling on the hub remachined to a bigger size (havent really looked into it) so my other option was to tap a thread through and go a screw in (loctite) .5" cro mo stud on the front. Any downsides to screw in?
Any thoughts
edit: seems you can drill new holes to the correct size (.007" undersize of the knurl) and press in new studs. Probably the answer.
just further to this Blaise, I suggest running longer than normal studs too. Look at long studs that drag racers favour (and some classes require). Using an open-ended nut, the wheel stud protrudes right through it, allowing you to easily see at a glance they are in fact done up, AND allows vice grips on the stud if you ever have a siezed nut.
^^^^ Cheers all. Was looking at the ARP Cro Mo studs. Figure they should be up to the task. Similarly woo was going to go a bit longer and get the quick start nose on them for nascar spec wheel changes :)
^^^^ Nice tip. Thanks. That will be the next thing to chase once the studs are sorted.
Seems i cant get a press fit stud to suit the mazda hub (shoulders are too big or knurl dia to big making the holes get dangerously close to the outside edge.
Looks like I will stick with 12x1.5 on the front but goa longer quick start nose cro mo jobbie and change the rear hubs to match. If that stud size is good enough for gazzilion horsepower GTRs it should be sweet for me. :)
Testament to a good YT cage. Driver spent a night in hospital (took his HANS off in the morning cause it was too uncomfortable), and the nav has a broken pelvis. But the doors still open and close! I'd hate to think what shape they'd be in with a shitty TMR bolt in cage.
^^^^ Hearing you. Just not the area you want to cut corners on. Bolt ins just should be an option for tarmac rally. Similarly, would not run without a HANS and side supporting seats. Unrelated, but I remember getting both front teeth knocked out as a kid playing hockey cause I took my mouth guard out for 5 mins cause it was pissing me off. Be gutted if you ran without your HANS and busted your neck or had massive head trauma. Bit like feeling like a tool for wearing your race suit at less than big events.....but would be a proper muppet if that was the event your car decided to burst into flames in.
And re the event, only managed to follow in the virtual world, but hats off to Rickards for what looked like an epic drive. And the captain for putting away all but the lambo. Farkin allright for a hairdressers car. :) Seems this fella in the 240z in classic can pedal as well. Pretty dominant drive.
Always like to think the best of other competitors... (I was one of the gullible f**ks that thought Lance Armstrong might have been clean... ) i reckon it seems they are relative new comers to the sport. (as I am) I reckon you definitely find more speed as you get a better handle on where to find the speed easily and where it isn't worth trying for it. Maybe just finding their mojo a bit. Seems they had some good pace on seasoned campaigners like Todd and Garwood. No doubt it must be a nice bit of gear as well. Be interesting to see if Rex comes back for TT.
Yeah sorry, didnt mean to insinuate that. To be honest with the very open rules in classic, I am not sure that you can :) But must have been a surprise to some of the more established crews. have definitely raised the bar. I am guessing just a new crew that have really taken to it. There must be a heap of undiscovered talent out there.
Edited by Darkside
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
