Ive not had anything to do with the MM events but id hardly say targa events are stress full. they seem to get more and more layed back every event
if you want stress full rallies give gravel rallying a go. id rather do 5 days of pace notes than one of gravel and road books and proper timing.
the one day events like the old buller sprints and poatina mountain race I think will become far more popular as I find most people I talk to don't have the time to put into multi day events
  • 1 month later...
Have spent the last two weekends fitting new rotors & pads, new wheels, change of all fluids and had the semis put on. Car's ready to go and I'm (hopefully) just as ready.
We recce'd a few weeks ago in an awful Kia Rio hire car so the course is fairly fresh in my head too. Can't wait!
Me = another one of the lucky buggers :)
Back in with Steve in the Just Jap car as usual.
Hoping to get my platinum plate this year all going well.
You need to whisper in someone's ear about another 0 car gig Benny!
My father will be there in the R33. I'm sitting this one out while his mate navigates and ticks targa off his bucket list.
The car is ready to go after a shake down at Marulan on the weekend. Just waiting on a new set of brake pads to show up in the mail.
Good to hear everyone! Everyone seems to be fairly relaxed and ready, most unusual! Must be "old hands" at it now huh :)
Wish you all a great event, and Kel, best of luck with the Platinum my dear!
I'd of course like to be back sometime. And to be honest, I'm not really sure what it is that's keeping me away? Maybe next year :P
I did very much enjoy the course car gigs, but Sam and Dan have put a lot of effort into that side of things with Jaaaaaaag, and good on them for bringing Jag to the party I say.
Any hot tips for class/outright honors? With the Lambo out who's the team for an outright win?
I'll be a mobile speed hump this year. 5 cars to look after. High chance of podium finishes accross 3 classes. I wanted a layed back targa but I doubt that will happen.
We had launcestons un official, official targa launch last night. Was good to catch up with like minded people. The field is definatly down this year.
Wheels are in motion for 2015/16 seat. 25th anaversary should be worth attending.
BTW I think Paul's car looks fantastic
So between this one, Ben's R32 and I think there is one other R32 it should looks like a Nissan racing re-union, love it.
Once they stop pandering to the sooky Porsche drivers and let R32 into classics I reckon we will see a few more done the same way.
i like!
good luck guise. :)
There's a tricky 32 in the full Neesan racing livery running rookie (driven by Dave Thompson).
Good luck everyone - catch up with you tomorrow!
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
