Hey blokes, Just found this on MotorActive and thought id post it up here for anyone whos interested.
Looks pretty good to me, im gonna buy a couple of bottles and see what results i get. Does anyone know who sells them? Autobarn perhaps?
Octane_Boosters.pdf
-Johnny
https://www.sau.com.au/forums/topic/233913-octane-booster-results/
octane booster is a waste of time. just get your car properly tuned to wat ever pump fuel it is you run.
+1
Octane Booster is a waste of money. i used sum in my r32 and it did fk all and burnt out my sparkies. u want more power put up the boost
Hey thanks for all the responses so far guys.
Im not after more power but i do want piece of mind. For instance, my car is tuned for 98octane fuel but if i add this booster will it provide a second line of defence against detonation on a hot summer day?
again im not after more power just a safety net.
is it true about the spark plugs, is it really detrimental?
Toluene (Methybenzene) has been around for many years (decades) as an octane booster/detonation suppressor. Just look back to F1 in the turbo era to discover the great benefits of it.
You don't need large amounts to provide a 'safer' mix for road use on hot days..... if you want to run more boost, then you'll need to add fair amounts in the tank, e.g., 10% is a good ratio I've heard.
I think one of the drawbacks is is can, over time, degrade rubber components in the fuel system.
Fixxxer
with a 10% tolulene mix i could safely run an extra 5psi of boost.
bit its dangerous stuff. use it at your own risk.
its carcinogenic :thumbsup::):nuke::nuke::nuke::nuke::nuke:
10%huh and 5psi more boost, ill just be happy to retard all knocking.
Fixxxer
Are these the 1.5litre race engines that push out 1500hp?
Rubber components huh, im not a real fan of that. Anyone had a bad experience?
i agree with jono on this one
out of all the power on tap options i find true injection setup the most useful and reasonable
i dont think adding in additives each time is useful, i dont think mixing fuel at home is reasonable
but a properly setup wet spray kit for meth / water or whatever is probably the most suitable
1.5 litre motor pushing ~900kw from memory. obviously there are very few people who know for sure, but a few 'experts' have summised that the fuel they were running was prodominantly toulene, octane rating ~150 somewhere i think. cbf looking it up.
Mafia, what is WMI?
Safety net?
How bad is the tune?
If the tune is fine - then you do not need to muck around with octane boosters or any other rubbish.
If your gonna go 10/10ths on a 40 degree day then that's your own problem and no amount of octane boost is gonna save you.
No-one else adds octane booster each tank, so why are you even worried about it?
Again, if the tune is fine, the car will be fine. Its as simple as that
I ran a 10% mix opf toluene for 12 months. Worked a treat bit was a waste of money, because in 12 months the money spent on toluene could have bought 1.5x WMI kits, that do a 10 times better job.
Edited by The Mafia
I used to add a bottle of octane booster on track days. Not for extra power but for reduced chance of detonation. These days I fill the tank and two jerry cans with Shell VPower Racing for the same reason. I add no timing or boost although it could probably take an extra 2 degrees.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
