Ill have a stab in the dark and say its a Vipec :D
Of course it is. Dirt man would be all over his arse shitcanning any thing else. ;)
he would say he was only joking tho. ;)
Edited by FineLine
im going over to the dark side mate. I am pretty sure with this ECU i can add a MAF if the MAP sensor pisses me off (this is a very good quality ecu so apparently this will not happen)
As for how the IM240 machine works at the RTA, i have NO idea.
But i do know how the machine reads, what it reads for and whats acceptable levels for whatever car.. I also know what levels are high medium and low when doing the dummy IM240 tests on the dyno instead of the guesswork i have been using previously.
Should be tuning another car for emissions very soon.
Fair enough , maybe having enough processing power to run everything in real time rather than count back etc may make a worthwhile difference . If it can self learn maybe the MAP system can stay on top of things .
My aversion is because I don't think inlet manifolds that work as an inlet manifold are real good at giving pressure signal clarity to a pressure sensing devise . The fluctuations in common plenum manifolds often don't give much idea what the engine wants because reversions don't mean much to an EMS . IMO the conditions upstream of the throttlebody/s
are what needs to known and a MAP sensor can't do that for you .
That aside I would always insist on having a system that can do MAF and MAP , like you said it leaves your options open .
I would also insist on something that can read the std optical triggers and run the six coils and fully sequential injection system .
Best of luck , cheers A .
yeah for sure!
I got another 3 emissions test to do... still got some more projects on the cards
once you get the map system sorted are you going to go for another emissions test?
assuming the MAP system wont be effected by reversion?
Hey mate
I did this for you on my last tank of e85 before going back to 98 (just untill i learn this new ecu)
I got 320km's to a full tank, and i did boost it a few times, did not drive like a granny. I used to get 350 - 430km's to a tank with 98
Once the car was tuned properly the e85 consumption was much better from when i first started.
Few things i noticed after the switch back to 98.
I have stalled the engine 4 times:
the fuel gauge does not go down to a quarter of a tank after 50km's
i cannot go up hills in 3rd gear anymore
i am changing gears more often then before.
i lost 40kw at the wheels
I am going to the United servo in Newcastle tomorrow to try and convince them to stock e85.
great thread mate, and very interesting work. thanks for sharing it. there is one simple little comparison I'd love you to do if you can. next time you fill up on e85 fill the tank full and re-set your trip meter. then when you go back fill it full again, read off how many kms you travelled and you can do a quick ltrs/100km figure. then try the same with PULP (if you ever use it again). XXXkms to a tank is a big vague as you have no real way to tell how much fuel is left in the tank and I don't even know how many ltrs a GTST tank holds! I'd love to know the ltrs/100km figures and it would add one more usefull figure to your so far very thorough investigations. :rofl:
Good luck with the test this arvo.
you have inspired me GT...
i've been looking into this for a bit and think i will give it a shot when e85 gets popular and we get pumps around melbourne. (ie after the v8 supercars start using it next year)
i've found a tiny laptop that i can permanently install in the glovebox for $400 and now i just need datalogit :) (CBF lugging around a loose laptop)
just hope my injectors handle it... dont wanna have to upgrade them again :D
I have 740cc, at what power level would the injectors be maxing out running E85? 330rwkw?
i got 340rwkw with e85 and was only up to about 70% injectors. heaps of room for more (i have 740's)
injectors are 555's i currently have 265rwkw on 19 psi 2835 pro s
you should be right to reach 300rwkw with e85
ohhh well just tell him its ok because you dont have a horse power figure goal, you have a KW figure goal =)
sweet... i was thinking 300 would be the e85 goal ;)
*cue ash telling me not to have a horsepower goal figure* :down:
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
