Better, e85 is cheap torque gains also, which are even harder to come by. On it's own the best mod you can do on a turbo car, if you can live with less K's to a tank, and have a pump locally.
The GCG is a bit of a mismatch turbo, mainly due to being stuffed into the stock housings. Best bet is to pick up a proper Garrett GT3076 and sell the GCG off, but then you need a new dump, intake, lines, external gate perhaps... the list can go on forever. Do some research before you jump in, as jumping up in power again from there may force you to replace all those parts again.
  • 1 month later...
Should i be a bit worried about using Caltex E85 when it was tuned on United E85?
It did have about 8 dollars worth of 98 in the tank when i filled it up with E85 before the tune though.
I run eflex occasionally on long runs, I didn't notice anything out of the ordinary. I think it's only around 4% richer than United I worked out. Still more accurate than a carby. ;)
It also means the mixture will be rich as a result of increased petrol content, which will compensate for lower octane.
When has richness ever compensated for lower octane? I know what you are saying in terms of it being a tad safer because its richer but that statement itself is wrong...
This topic has been brought up many times, discussed thoroughly, and concluded by enough people who know SIGNIFICANTLY more than I do on the subject that it will make sweet f**k all difference when it comes to any risks brought on from ethanol content change and subsequent RON change.
Just wondering what spark plugs heat range you guys are running?
I have my S14 SR running on E85 making 280rwkw on E85 and are playing around with plug choice.
some say run a cooler heat range some say run the standard 6 heat range?
I have tried going from 6 to 7 and even colder plug in 8's.
What are the yays and nays of these different temp range? Apart from the starting up difficulty with the colder plug what else is to be considered?
Yep, here's a paper that backs up what you're saying.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CDUQFjAA&url=http%3A%2F%2Fdspace.mit.edu%2Fbitstream%2Fhandle%2F1721.1%2F69496%2F775670245.pdf%3F..&ei=am8vUaHdBYj88QT6xYGQDQ&usg=AFQjCNGwXDKnWr9zhWOVwjfkHqrqsQZSyA&sig2=PlJh-ScUjRaOaCrwqunmpg&bvm=bv.43148975,d.eWU
Basically once you get above 40% ethanol content on a port-injected engine the detonation resistance of the fuel plateaus. So at minimum E40 "should" get you the same benefit as true E85.
Disclaimer: not an expert, read the full paper and decide for yourself :P
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
