lutch will max out at 300 anyways.
So only wanted to get about 280-285
My gearbox has been out 3 times already so I'm not too keen to go down the slippery slope of upgrade after upgrade
You don't need to upgrade injectors for that power goal.
scotty seems to think everyone wants over 9000 killer wasps
  • 1 month later...
  • 2 months later...
Washable stainless filters are not fine enough, the dreaded black gunk seems fine enough to get through them and clog the injectors. I was recommended to install 10 micron paper elements to guarantee it would catch the black crap present in e85. (I assume from the manufacture of the fuel.) Moran refuse to warrant their injectors without a similar filter fitted in the fuel line...
E85 is a great cleaning solution and should flush any varnish buildup through, but this can block the filter internal to the injector, which in the EV14's is nearly impossible to clean.
wait, what? gunk in E85 from the manufacturer? (I thought it might happen if petrol stations filled ULP tanks with E85 without cleaning the tank first).
Is this a common problem or isolated?
Common, it builds up over time and circulates your fuel system, building up in the injector filter eventually. (Which is deep inside the injector on the ev14's.) For some reason my fuel system has been fine for years, but I have replaced 3 sets of ID's for customers due to this black crap recently.
I have a feeling it is from the carbon filtering of the ethanol during production. It does look a lot like carbon silt.
Currently running my rb20 on e85. Using a bosch 040 intank pump, all lines are speedflow series 200 hose (teflon), with tomei fuel reg, aeroflow inline fuel filter, standard fuel rail, and 565cc hks injectors. Making 266kw/357 hp, and mine doesn't chew through fuel like that at all.. Dyno graph in the rb20 dyno result thread
  • 3 weeks later...
Nah easy. I just carry a laptop with a 98 tune on it in case I have to stop for 98. It never fusses over a few litres of E85 left in the tank, and vice versa.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
