Interestingly, I've found the GTX cards to be understated in almost all graphics/games benchmark tests. Either matching them with shitty hardware or AMD been shaking hands with people!
Recent testing in the office shows otherwise.
290 / 290X cards smash their NV equivalents in all of the benchmarks - the 290X we tested was definitely faster than a 780ti. As for the cooling issue, we used a Gelid aftermarket cooler that dropped temps in Uber mode by 20 degrees.
they might run hotter, but at a significantly lower price, they're a pretty compelling buy, especially for >1080 resolutions. This is from a place where we've all always been all Nvidia as well
Problem is you need the aftermarket cooler, you can OC the stock cooled reference TI like a mofo
Either way both great cards, but not a fan of ATI drivers really. Oh and seen some evidence that shows mantle to be worst looking in game for dat dere 10% or what ever it is in bf4 lol
Benchmarks aren't everything though, quantity over quality sometimes. An example being that BF4 is made for ATI cards, so similar specs and benchmarks will still favour the ATI in an FPS contest. Bitcoin mining being another. But not all rendering is equal, and drivers/support/control/OC are very good in the NV house. 290 seems like very good value all round.
Went & bought a netgear 4 bay Nas unit along with 3x WD 3TB red drives to off load all my animes/movies/TVshows to that instead.
One of my old 2TB WD green is dying (WD20EARS) & luckily I had most of the stuff on there backed up to a external drive before hand, seems like all the drives that have shown signs of dying were WD greens (2 so far), with the exception of 2 segates that were DOA... the oldest hard drive, an old samsung 7200rpm unit (that I use as my main game install drive besides the SSD boot drive) I salvaged from my old PC bulit is still working flawless.
Random people have being telling me leaving bit torrent running wears hard drives out faster, Is there any truth to that or complete BS? That dying WD green was one of the main drives that I had BT constantly running most of the time, coincidence?
Edited by Mayuri Krab
Yep seen enough failures of Greens on various RAIDS - the speculation is that the drive's powerdown energy saving features create havoc in the array. I'd be using regular drives.
If you're paranoid about drive wear, use a Red or a Black / Blue as a scratch disk for your torrents, then have them automatically move to a Green on completion.
My standalone Greens have been going for 3-5 years respectively, no complaints, make sure they get adequate airflow and aren't subject to vibration
planning on doing some shopping next month, am tossing up between EVGA GTX760 (because i like EVGA support + tools and ive only ever had nvidia cards) OR sapphire R9 280X (got some good wraps. would have preferred a toxic, but extra $200 for some cooling...)
nvidia has better base clock speeds but more pricey... i would prefer SLI over cross-fire mainly due to chipset availability in next 12 months.
http://www.scorptec.com.au/product/Graphics_Cards/NVIDIA/51149-04G-P4-3768-KR
http://www.scorptec.com.au/product/Graphics_Cards/AMD/51789-SA-R9280X-3GD5-OC
also thinking of picking up another SSD
http://www.scorptec.com.au/product/Hard_Drives_&_SSDs/Solid_State_(SSD)/48725-CSSD-F128GBGS-BK
and desperately need new keyboard
http://www.scorptec.com.au/product/Keyboards/Mechanical/50630-DK2108S-AUSALT
I'd be looking at a old 680, or 770 GTX (considering they are the same card, and better than the 760 if you gonna spend $400)
e.g http://www.pccasegear.com/index.php?main_page=product_info&cPath=193_1486&products_id=23601
also the samsung SSDs are awesome
I got the 280X (and after a few hours of trying to get drivers to work) seems pretty good with Rome 2. runs nice and cool.
Samsung and Corsair are same thing basically, ended up with Corsair 128gb and meh: its a hard drive.
ah yeah thats right forgot you were having driver problems lol
and yep thats it, my ssd isn't the best anymore but in terms of real world performance meh not going to notice any difference if I got the latest and greatest one.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
