can i have a drive of your car Steve ???
i'll let you drive my 235killa wasps :)
how do the RS's respond on a 2.6L compared to your 3L?
Lol, maybe :huh: Wait till the brakes are on it and the tune finished, then it will be much nicer
never had them on my 2.6, but in other gtr's with them on, I havnt been impressed-for all that lag they may aswel be a to4z
  • 4 months later...
425kw's at the rear's best so far
HKS Step 2 - 2.8
HKS Twin GT2835's with 0.6 A/R's
Nismo inlet manifold
20psi
HKS Step 2 - 272's
HKS Twin spark with Spiltfire's
Power FC
Pro ported head and chambers
8.7:1 comp ratio
No print out handy at the moment but should be shortly
  • 2 months later...
atm sitting on 410 rwkw mods include;
ENGINE:
rb25det block
rb25det head no work done
linshed standard crank shaft
cp 20 thou oversized pistons
eagle h beam rods
acl hardened race series bearings all round
arp head and mains studs
n1 oil pump
remote oil filter with 15 row cooler
n1 water pump
hks 264 duration camshafts
hks adjustable cam gears
plazmaman plenum and fmic
sard 850cc side feed injectors
aeromotive fuel regulator
hks t04z turbo .82a/r rear housing
6boost highmount manifold
hks 50mm wastegate with screamer
3.5"dump pipe
high flow cat
3 3/4" cat back
FUEL SYSTEM:
bosch 040 intank fuel pump as lift pump
2l surge tank
twin bosch 044 inline fuel pumps
twin #8 fuel lines to fuel to twin entry fuel rail
TRANSMISSION:
jatco 3 speed manualised auto
400kw transbrake
18psi stall convertor (4,600 rpm)
13 row oil cooler.
ECU
haltech E11v2
FUEL
BP ultimate 98 oct
CP Pistons
Eagle Rods
Tomei 1.2mm Headgasket
Tomei 1mm Oversized Valves,
Tomei 270/270 Procam 10.8mm Lift
Tomei Valve Guides
Tomei TypeB Valve Springs & Retainers
HKS GT-RS
BNR34 with 425awkw on e-85! Who says HKS GT-RS on 2.6l is laggy? :(:O:)
Was pushing for 30psi, but due to catalytic converter boost dropped to 25psi will fix and decat it to make 450-470awkw
hahaha its the 94mm trust exhaust. Though i bought a metalcat and its probably what is restricting it they said as i got it installed and after the front pipe it joins at a 3" then the trust 94mm, though it will definitely get fixed up and sent back to powertune in a week or two so will definitely update to see it go past 450awkw
Hmms R31, why do you keep saying rwkw? I ran it on a awd dyno at powertune. Hmms not sure if i can make 500awkw on my engine, might be able to on higher boost, but only problem is i am only running SARD 1000cc and really i find it no point pushing it any harder, am happy with 30psi because it fliesssssssssssssssssssssssssssssssssss so who said gt-rs was laggy on a 2.6L? ;)
hahaha n1gtr, no need and no point wasting anymore money in my opinion! i do have a 3L block in my garage as an 'option' if i wasnt happy with GT-RS and 2.6L
Though from what i experienced today and knowing it will do 450+ as soon as it can hold 30psi anymore power is just ridiculous!!
My only goal was to just have a 10sec gt-r haha! will run soon!
Though maybe if you took me in your 26/30, hmm i might change my mind? How about i take you for a ride and give me one then and we'll compare? ;)
awkw/rwkw same shit mate.
GTR's are NOT 50/50 fulltime 4WD like a EVO/STi. People need to start realising this.
It's been proven time and time again there is minimal difference between the two. 10-15kw difference as tested on several cars over 400kw @ the wheels by various users now on various dynos. Have a search for the threads if you don't believe me ;)
IMO 425rwkw/awkw and E85 is a poor result for that much boost when -5s (read: smaller turbos) would make those numbers on 24psi/E83
Oh and you easily have a 10 sec GTR with 425rwkw, you can run mid 10's with less than 400 :D
awkw is run using four wheels, rwkw is using rear wheels? hahahaha...
I know its not 50/50 but you would still consider it awd right? 60/40? still an awd system.
Anyways, i already the difference and have seen and read it several times. It is only running 25psi for 425awkw as the boost is dropping. Either way its because i told him not to push it too far also as i dont want to make the extra power and then risking the motor. Either way everyone knows its not always about the numbers, its about how it drives and as i said, who says hks gt-rs lags on a 2.6l? :D
Hahaha yeah i know, a mate of mine ran 10.98 with 350awkw so i know its possible just wanted to do a time for myself
Though maybe if you took me in your 26/30, hmm i might change my mind? How about i take you for a ride and give me one then and we'll compare? :D
Deal.
Broke my foot yesterday so it won't be soon thoufh
hahaha woot! two offers to see what the 26/30 is about... yes i am in sydney guys! Maybe we'll meet at the r32 cruise on 10/10?
I wont be going to cruise, will drop by at penrith though and if anything we can go for the spin there? ;)
Hopefully be running 450+ by then and you guys can tell me what you guys think? :D
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
