For it to be closed loop it will need a signal input from the camshaft position sensor that you will need to install. You can't just use RPM as an input for closed loop as it's unrelated to what you are adjusting
I thought he was talking about open loop control, but yes if closed loop you obviously need an input as well.
We are looking into an rpm box for you guys.
I've been using the msd rpm switch for a while now... sturdy bit of gear.
I'm suuuper keen to get a hold of 25 VCT conversion parts and camshaft from you once it's all sorted. I'm suprised no one has developed it yet???
Do greddy still make the adjustable cam sprockets for the 25 vct cam gear?
sign me up-
Cheers
Justin
I'll look into that thanks.
The factory RB25 inlet gear is adjustable....it's just on the back of the gear :(
I have seen someone do a bolt configuration through the gear so it was adjustable from the front.
The MSD RPM switch looks like it only turns something on at a specific RPM? We need to turn it off again at a certain RPM so that means it would need to be programmable
Look for a MSD RPM window switch, a RPM Switch is on... A window switch is on and then off :)
I'm just using a on switch mind you, works fine
Thanks.
They seem to be what we were looking for. And only about $150 so also the right price.
what intercooler, are you running??
His car has the basc 70mm ARC GTR intercooler. They're a good bit of gear. Light, good flow and good cooling. They are actually lighter than a stock GTR intercooler!
i was pointing more at v8 vvt that run 4 cam sensors
like the bmw's and soon to be nissan v8's
run them as pairs in/in ex/ex not often you want different valve timing event between left and right banks.
Thanks.
This is what I use:
http://www.msdignition.com/Products/RPM/Timing_Controls/RPM_Controls/8969_-_Digital_RPM_Window_Switch.aspx
Cheers :cheers:
J
Woudn't trust a eboost to switch anything on, they are a POS at the best of times
cheers
darren
Mines works great, what is the issue you have with them?
Controls boost well, window switch works great, lots of people recommend them?
I've never had problems with the unit or the solenoids on, only the people who wire them in incorrectly. I'd say most people's grief would be caused by the same thing
They have a bad habit of just locking up , outputs stop working at same time and you have to send them back and get them updated.Eboost 1 and 2 do it. ... I am not the only
one who had that problem, a mate had the same problem , and if you look around, a lot of the sport compact racers have had the same problem
Its actually quite common and a lot of workshops won't use them for that reason, as i found out after mine f**ked up.
Not good when its hooked up to your water injection solenoid that for sure
I wound't buy a second handy of ebay, thats for sure!
When it worked it did do a awesome job of boost control, funnily enough mine got stolen out of my car when some work was getting done to it, before i had a chance
to get it updated, hopefully it blows the thiefs car up ..lol
cheers
darren
Edited by jet_r31
i've got 2530's, which are almost identical, and with baby cams still managed 400rwkw with E85, only 21psi as well - most people run 260 cams, and prob more around 24psi is the pistons/everything else can take it, you'll walk in the 400 with -5's :)
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
