are you sure it was an RB? i remember a VQ30DET with a manual gearbox doing some burnouts in a street
Thats the white one, yeah?
Im thinking of a red one (or Pink as we'd refer to it when Stephen owned one). Im not having too much luck on the googles, perhaps I'm going insane pinch.gif
  • 6 months later...
A NZ bloke who seems to pop in occasionally is the closest to getting it done. "dcdc" is his user name.
Last time he checked in he had a R34 getrag 6spd (I think, i know it was a GTR box) in the car, had to be a custom bellhousing. Combination of parts isn't that hard to work out- GTR box, V35 pedal box and clutch cylinder, Flywheel off something to suit, clutch plate.
Then a load of head f**ks getting the ECU to take to something with different speed inputs / loads etc etc, as the ECU was never designed to work with a manual box- so its not a matter of switching auto/manual ECUs.
He had to cut the floor plan too to fit in the T case.
RWD would be no doubt simpler, but you'd still have to get around the electrics side of things- just use a V35 1/2 cut.
Whatever option you choose, expect north of 5 or 6k for the RWD, and double that if going the AWD as my guess. Thats if you expect drive in drive out. If you are a fabricating God, then you'll already know where to start.
Actually dcdc is in Brisvegas. I dropped in to see his M35 a few weeks back. Looks quite the project but still a long way off being completed.
Yes a different KIwi manualised an M35 2wd with a custom bellhousing and Toyota box - used a Link wire in to run the engine (turboed 3L)
Yeah I remember that one, it was in a Mag, and saw a vid of it doing skids. Its was a VQ30det from memory. Different ECU setup from these VQ25det guys. Think it was out of a Gloria or something.
  • 1 year later...
**Thread Revived**
So if I understand correctly from what I've read here the last page's...
"Converted from an automatic RS4 and had a totally reconditioned r32gtr box with a set of nismo heavy set gears whacked into it"
...right!?
...otherwise you have to say that there is nothing what you can do even without spending a fortune equal.
Bad story,for this car :(
The C34 one has been more effortless!
**Thread Revived**
...right!?
The C34 was released in manual, and has a programmable ecu. The M35 does not, and parts seem to be nearly impossible to find. (I have been trying to find a manual V35 console and handbrake for years)
The conversion is still going ahead, as soon as my Evo is built and on the road. I just hope I can find at least the handbrake by then.
Didn't the m35 have the 350s with the factory manual?
Yes.
It was a series one car modified by Autech.
And Scotty is just being a bish. All he needs is a wrecked manual V35 S1 sedan, but he keeps buying nugget Stageas for parts cars...
:P
Yes.
:P
Series 2 you mean?
There is no gearbox other than the RE5 that bolts up to our orphan, I need to swap the sump so the bolts line up on the 350x box, and the starter fits. There is a lot of mechanical work before I even get to the electronic side. :/
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
