When a car rear ends another car it is always the back cars fault, even if you stop to do an illegal u turn, slam on the skids for no apparent reason etc.
The exception is if there is an intoxicated driver, then it's his fault no matter what.
A mate of mine found this out the hard way, he was in a 6 car pile up at a set of traffic lights, in the middle, and had to pay for the lot after he blew just over the limit (0.07 i think) He's still paying it off after 5 years
its not skylines that have a crap turning circle its because of AWD
nonsense. the geometry of the car is the same with AWD. when you lower the car, the front wheels go back an Few centimeters. I lowered my r31 ages ago with shortened king springs, turning circle was greatly reduced. do the math instead of saying 'oh its awd' - that is unless your definition of turning involves flooring the accelerator and spinning the rears...
-D
Edited by Dohmar
-D
Sorry Off topic , but the driveline on AWD and 4x4 binds and front wheel drive too, killing the turning radius, the numbers dont lie
GTR R34
imentions Length 4600mm Width 1785mm Height 1360mm Wheelbase 2665mm Turning Circle 11.2 m
R34 GTT
Dimentions Length 4580 mm Width 1725 mm Height 1340 mm Wheelbase 2665 mm Turning Circle 10.2 m Chassis & Body
Edited by sapphiregraphics
-D
no i have no problem with turning circle or any circle for that matter
http://au.youtube.com/watch?v=WPrKQLtbLGk
GTR R34
R34 GTT
But the 4wd is not active during slow driving and the front diffs are open wheelers, well they are on 32/33 GTR's not sure about the 34's. Maybe they have less turning because the front drive shafts limit the amount of lock that can be used.
Edited by DSTROY
a little of both chad its my understanding that with the front CV's you cant turn the wheel as far lock to lock and 33'2 onwards have about 10% preload on the front transfer case that's why we cant just pull a fuse
Big thumbs up for shannons here. Had a not at fault claim last year and everything was so silky smooth.
Anyway my insurance:
R32GTR - 17k agreed value, Premimum just over 1k (about 1060 i think, cant be bothered finding the paperwork), $500 excess
03 VW Bora 4motion - 20k agreed, premimum 860, excess 300
99 VT Wagon - 7k agreed, premimum 560, excess 300 (somebody buy me :P)
Pretty happy with what im paying since im 22, that said i've got a clean driving history and have never made an at fault claim!
Dont forget guys, if your with shannons and have your cams license you get a 10% discount on your policy's!
true damo, hopefully they post only if the insurance is just in there name, cause in the parents name its pointless to hear numbers. the rates will vary dramatically if mum is the "primary driver" lol god I would hate to be in the car with my mum driving a car with power she had a 928s a long time ago but since then puddle jumper cars...lol I cant even let her drive in low power car , i dont have a death wish,,,, she is too cautious to be safe..lol
Very well said mate
My quote is genuine as i called up and they would only insure the youngest driver
so the quote is under my name and only me
Try doing a online quote with Shannons... they don't even have Skyline listed for ANY year!
Edit: and you MUST be 25+ to even get a online quote!
Try giving them a call mate
I had troubles getting online quotes
So i gave them a call and got a quote all set up and shiz
never been so happy lol
more and more shannons customers under 25....
About 2yrs ago they changed their policy i believe about under 25 drivers, the change meant that if you were under 25 and drove a performance car they would be less likely to insure your or would not at all. However i've been with them for some time now so i slipped in around this. According to my insurance guy at shannons if i were to try and get insurance now with them and i'd never had a policy with them before i'd be declined.
Oh and for any performance car in most cases it needs to be in a locked garage for them to cover it too.
Yup my policy's are in my name only. I too would hate to see my dad drive any of my cars as he's never driven a car with power + he's not the greatest driver as he's too carefull yet careless at the same time (drives slowly but carelessly). The most powerfull car he's driven was a 1.6L fwd pulsar.
Edited by WhO
I think thats what sealed the deal for me with shannons
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
