Sometimes i wish i'd bought the 3037 instead of the GT-RS.
Best decision i made was to get the 3037 .68 rear, making 337 on E85. Still responsive too....
  • Replies 489
How much was it?
I brought mine off a fellow member and the turbo had 5000k's on it, from memory it ended up costing me $3200 for the complete kit. Not too bad considering what they are selling for now.
Good price that.
Bought my gtrs for $2750 2 years ago.
anyone got a set of indy blu's i can throw in and use the e85? ps. anyone used 100% meths? (chemcal factory next to my work can get it to me for $1.20/L
i was going to go methanol on my sr20, problem being the maintenance required. Any decent power WILL require 2 sets of indy blues per cylinder. Most people in the know say big electric pumps are OK, but mechanical driven is much better. But then they are a flamin mongrel to start with mech pump and you need to gravity feed the fuel in (thats why they run small tanks in the engine bay) then you need a special mech pump reg (not big deal). but then you need to drain you oil after each event you run at (mostly) run normal petrol through fuel system and run the engine or you will corrode the bores etc. "usually" dont run filters either as they can trap meth and turn to jelly.
Edited by GTR1993
Give it a try, might need 2 rows of indy blue's to make real big numbers!!!!!
Brazil's been useing 100% for years, would need high ambient temps to get he stuff to fire tho, even 85 gets hard when temps get below 10 degrees
good result, but I would love to see a graph of what difference it made at the same boost. I know you're saying you couldn't run more boost with the 98RON, but it was only running 14psi at the top end with a spike to 21psi as it ramped onto boost. I would just want to see what gain the fuel itself made. same boost, but with more timing etc it can apparently take. as it is a lot of that gain would be from more boost (more air + more fuel = more power of course), and i'm a bit surprised that the most you could run was 14psi on 98RON.
anyway, enjoy the new power and sweet smelling, cheap fuel. :glare:
sorry... on 1 bar the e85 made just on 300 by memory...
i cut the boost on each fuel @ the point where it was starting to die off... (dont wanna run 2 pounds more to get 5rwkw gain)
price not my main concern, it's all about the RON man, oh and the huge torque that 24 psi offers, love it!
I can agree to this.
It definitely doesn't have that typical weak RB25 ramp up sound when on the dyno. 180or200's car had me thinking it was an rb30 the way its mid range picked up instantly and roared as the loud pedal was opened up.
Thizzle made 301 with a GT-RS and stock motor 3 or so years ago.
There is hope!
I'm with Ash; sounds like he was on a happy dyno or the settings were incorrect. Did he ever back the power claim on an independent dyno?
I made 274rwkw with cams and head porting. This figure was also reproduced on two other dynos, so i dare say it was accurate.
With E85 i could see the GTRS making 280+rwkw on a std motor.
On the DVD it made like 298, 297, 301 or something along those lines.
But on the same dyno.
To back up the claimed figure it needs to be run on another dyno.
Like mine made 274@EAS, 268@Racingline (SAU VIC Dyno day) and 272@Autosalon. Thus i know my mechanic's dyno is relatively accurate.
Nice results :devil:
Excuse the ignorance, I haven't bothered to read anything about this fuel...
but 85% ethanol? People were pissing and moaning about 5-10% ethanol destroying fuel systems etc (I personally ran V-power racing for a period of time with no issues, and 1 tank of 100RON United which I think has ethanol as well, with no issues) but 85%?
Has this question been addressed? Also, what is the equivalent PULP RON (if such a comparison can be made)?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
