With high EBC loading, the boost pressure before cooler rises, but what inside inlet manifold doesn't change. Here's some thing fun to watch. Our TD06SL205 turbocharger on a CA18det pulling 307rwkws E85 fuel. Run 11 sec quarter:
Eastern Creek video footage from Sxxreco, Unopened Rb25det, using our 21U high flowed turbocharger making a super responsive 310rwkws on E85 fuel:
  • Like 2
Gday guys, I just wanted to post up quickly my results from a hypergear op6 hiflow on my R34. It was tuned by Trent at mercury and made 265rwkw @19psi on pump 98. Very pleased with the result, the power delivery is nice and smooth but still kicks you in the ass once it gets going ;)
Cheers!
updating some 1JZ results. Those are from 1JZGTE Chasers:
This is 292rwkws on 19psi on our TD06SL205 Turbocharger externally gated, P98 fuel, Unopened engine:
And this is using a high flowed factory CT15B on E85 fuel making 321rwkws.
Can you machine the TD06L2 (61mm) exhaust housing to take the larger TD06 turbine (65mm)?
Its been a few weeks getting the new test car ready and I've spent quite some time diagnosing a boost ceiling issue.
For today's test, I've tapped two extra boost sources on both sides of the intercooler piping, and monitored pressure drops on all four points.
Surprisingly it is a issue with the actual intercooler it self. Three intercoolers was tested, they were the Takashi (a good Chinese made cooler) in 600x300x68mm, 600x300x100mm, and a Generic ebay cooler in 600x300x76mm. Final result reviews the 600x300x100mm Takashi cooler had the best response, while the Generic ebay cooler made the most power.
I will likely be trailing a PWR item of a similar size, hopefully an expansive branded item could solves this issue.
Final result was peek of 281rwkws @ 19psi after cooler pressure on Pump 98 fuel.
ATR43SS-2 Internally gated
ID 1000cc injectors
Walbro fuel pump
Adaptronic Plug in ECU
3inches turbo back exhaust
Tune at Chequrered Tuning.
The last sheet shown the same turbocharger working with same type of engine but return flow cooler kited. Notice lag created of having extra piping length.
For best result on a Rb25det R34, Get a proper FMIC kit with a big free flow intercooler.
So that graph above shows a difference of around 750rpm extra "lag" with return flow pipework?
Is this a pretty typical result?
I run custom return flow style pipework, with 2.5 inch pipes and a pretty tight radius off one end of the cooler. Have been wondering for a while if any gains were to be had from going a traditional front mount style pipes.
My setup is laggy, but I think thats more to do with the turbo choice, and RB20 haha.
Would be interesting to see how a top mount setup might go seeing as you could really reduce the length of the piping. Don't know how you would go about fitting one for practical use but would be good to see what it could do on a dyno for some giggle factor.
  • Like 1
Nope, it's a daily so not necessary. The water radiator is quite large though, almost the size of the radiator and is sandwiched between the air con condenser core and the radiator for stealth. I haven't got around to logging temps properly yet (there are temperature senders in the top and bottom of the radiator and I will be placing them in the intercooler outlet too) but using an infrared temperature gun shows the IC outlet temps stay close to ambient on the dyno.
Throttle response is instant in every sense of the word as expected from a stock 21U turbo on a 30DET with an automatic gearbox. It'll be getting one of your highflows hopefully later in the year once a few other mods get done, most likely OP6 based.
Nice, I will be looking forward to your job.
In this car I'm mainly looking into some common mods that majority of people use, and this definitely shares to some of the problems that few people experienced, especially in the cheap and stealth category. I will be looking into possible ways of targeting those problems through a turbocharger.
Here is some thing fun to watch. :D
  • Like 1
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
