This is a prototype ATR43 G4 520HP CHRA. It runs on shortened bearings and weigh reduced turbine for maximum response. engineered to produce about 300rwkws at 20psi on .63 ATR43's turbine housing using RB25det engine with supporting mods.
The smaller one on the photo is ATR43 G1 350HP CHRA. Its made for 240rwkws with excellent street response.
Compare to ATR28G4 it has lighter turbine with shorter bearings. So it should have slightly better response. I might update this CHRA into the ATR28G4 once its been evaluated.
Turbine housing is getting made. I'm going to swap this 2x with my existing high flowing customers. probably Geraus and SS8_Gohan for some dyno and evaluation results.
For time been we will still be using proven ATR28 CHRAs. Price wise I don't know at this stage. depends on how much it cost to build the rear housing.
hi,
i skimmed through quickly but didnt find the exact answer i was looking for.
what turbo would you suggest is the most efficient/responsive for a Rb20(r32) wanting to make 240-250rwkw while keeping the stock manifold, but being externally gated.
thanks.
hi,
thanks.
i went with a ATR28G3 with 0.63 internal gate rear for my rb20... i'm looking for a tad more power than you
so maybe look at a ATR28G2
hook us up Stao :P:ninja:
we going to need new dumps? and am i going to have to run stuff in again... done so much friggen running in with this car :P
EDIT: so are you saying these will be laggier or potentially, they might be a little more responsive and make a bit more power?
Nice love the pointy wheel. Hopping to see the complete turbo and some results soon.
ps.
would this punch a whole on my foot if I drop it upset down? :ninja:
Edited by kwickr33
Today got the turbine housing made. It is .86 in a T28 which is equivalent to a .63 in a T3x.
It is bolt on to stock T3x manifold and 6bolt dump.
The Very first ATR43i 520HP G4 in T3 .64 Turbine is complete:
We'll be making few more different A/Red turbine housings in the next few weeks. We will also be engineering a 650HP profile CHRA to suit a .84 Bolton Rear housing.
Well stock turbo won't make 520HP. Bigger turbos will creat more lag. This is a G4 profile, made for 300rwkws.
We also have this in G1 and G2 profiles which are rated 350HP and 450HP. The G1 would have very similar response as the stock turbo to produce max of 240rwkws, G2 is about 300RPM laggier but but its good for upto 270rwkws.
Price wise This turbo is $1300 to complete. With normal Turbine housing which comes out in a Vband rear is $1050 internally gated. or $950 externally gated with a 5 bolt flange.
didn't i have a G2 originally? that was about 230rwkw at 15psi -
gotta remember, "most" people won't be bolting these onto built engines (IMO) - they'll chuck em on, run 15/16/17psi and that's probably about it. I'm only running a bit more boost because of E85, otherwise, 17psi would probably be my max.
will give you a call/email asap about the .63
Yes but that was in stock R33's turbine housing. Now they are running in a .63 T3x rear housing, The spec of it is very similar to a GT3071. So it should make around 260rwkws at 18psi of boost on 98 fuel
do you also make this turbo with an externally gated rear housing?
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
