How does the dump fit with a different core on the turbo? or are the cores the same length?
Every thing fits the way it was, they are still your OEM housings. The T2x bearing housing is few mms short. But it doesn't affect installation.
Can possibly high flow it with a BDR351 Comp wheel working with GT45 turbine wheel. Should pump out 1200HP. What sort of housing is it in?
not sure on the rear housing size havent checked yet i would only want it to flow 1000hp anyway would the rear wheel even need changing for that?
Depending on the engine size, for 1000HP you will need a 1.2 A/R turbine housing, and 87mm 85T turbine wheel. The T04Z runns of a 74mm 76T turbine wheel which is rated to 700HP, so it needs to go up in size.
Either way its not a cheap exercise so unless your T04Z is blown, its probably worth selling it and buy the T51R which we can supply at a very reasonable price.
My concern with that is if both cores ar 2-3mm shorter than the gap between the turbos opens up 4-6mm, thats enough to mean that double layered gaskets will be needed or it will leak like a sieve.
Very good result for stock Rb20det, how come its so wavy on the top? ignition problems?
It's a hub dyno so they don't have the power dampened by the rollers which usually smooths out the curve... Plus RB20's always have a bit of a wavy top end
No ignition problems at all (had a lot more boost it in and didn't miss at all)
This was with a G2 in .63, My engine blew up on dyno during the next run. Even thou that made the power and response, I still prefer .82 for high performance RB25det. unless if that was a 3576 profile.
.63 works out ok on RB20dets.
You find Rb25det with .82 rear makes power lot easier with less boost and lot less heat.
What would lag be like though? Could it make 250kw at 120kph / 4500rpm ish like that does?
only cos for me i wouldnt be at the top of 4th much on track if at all (drift), or road so thats why i was thinking the .63 could be better for that reason?
Edited by raZ1911
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
