You get full boost by 4300RPMs with RB25det using .82. It pulls lot harder.
If your purposes of buying this turbo is for mild power street use the .63 is fine, But it does get really hot under high boost if you use it for drifting or tracking.
Another small update:
Still remember this ATR43G3 unit with .82 turbine and .70 comp?
Got it dyno tuned today, car mad 298.5rwkws on 21psi with miss-fire. Only done 2 runs, car miss-fired very bad after, we changed plugs cleaned coils and nothing helped. I will give another try with splitfire coils in few weeks. I didn't grab the dynosheet this time. But dyno footage with 3 people in the boot is worth to look at:
(click on photo below to watch that video footage)
Also my engine comp shown:
130, 125, 125, 120, 125, 119
Next run will be with a new forged engine :miner:
nice power how much for the turbo? and what mods does it require to bolt up
Peak power was around 7000RPM. Check the 2nd run with people in the boot.
Power rise till red line, the curve is very similar to the 268rwkws run with restrictive intake and the 316rwkws run on with the sil180.
car was not strapped with wheel spin, Reved to 7000RPM as usual.
Next run will be with a new forged engine :)
These are the ones i wanna see more of :) 0.82 has a better power torque balance than 0.63.
I think this turbo is the same as my ATR28g4. Getting slightly better spool now with my alternator changed. Hitting 1 bar just after 4000rpm with no boost controller. 10psi Actuator with heap of preload
Further updates:
Apart from turbochargers our engineers are also dedicated in to engine building, how ever I'll not provide this service to the public. I will show every one how it’s done and costs involved. Any useful advise is welcomed.
Primary goal:
This engine will be used for our turbocharger evaluation pusposes, My goal is 350rwkws.
This engine will be built with stock cams using forged pistons only, so Power vs Boost generated from it would be identical to any other healthy standard RB25dets.
Engine:
96 model RB25det engine bought from local wrecker.
An hour later its in bits:
Cracked piston in cyc 6. But bore seems to be in ok condition
I’ll be using forged CP 20 thou over sized RB25det pistons with rings and pins. The piston set cost $1150 AUD.
Engine block's been sent away to Reflex engine services. Its going to cost $260 to re-bore all 6 cyc with block thermo bathed. Engine head cost $250 to trim and bath.
Also for people whom owns a pair of CT12a Powered 1JZ Soarers. We can high flow them to 2860rs Disco CHRA specifications in sleeve bearing:
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
